Hi, I have a 1985 LT1 that runs great as long as you are getting on the throttle hard but skips, runs very rich, and sometimes wont idle correctly when sitting in park. Other times it runs fine all the time but then when it takes a notion to it starts acting up again. Any ideas? Thanks in advance.
could be the mass air flow sensor or the power relays to it. Pretty sure the 1985 had unique relays for them, it has been a while since i had an 85 so hopefully someone with more knowledge of that will comment.
Before going too wild with replacing parts around the MAF (They get expensive on the '85) I'd check and make sure you don't have a vacuum leak and that your injectors are reading good. More importantly though, check your fuel pressure, see if it leaks down quickly after you turn off the car.
I have a leaky cold start injector that causes it to run rich occasionally and demonstrates similar issues when my car is cold. Once it warms up and goes into closed loop it runs like a champ.
As suggested, do this free stuff first to get a better idea what is going on.
