84-85 vet
I suggest you obtain a copy of Corvette Specs: 1984-1996 Models [Paperback]. Mike Antonick (Author), Michael Bruce Associates (Author), Michael Antonick (Author).
This paperback is a pretty good review of the C-4 years. A lot of changes to engines, suspensions, interior, exterior, tires, etc, etc during these years. For example, the press LOVED the 1984/1985 handling but most folks found it too harsh, and Chevrolet lowered the spring rates significantly in 1986.
Some time spent reading will help you zero in on the model/year that will be a best fit for YOU. Spend some time looking around, there are good prices on good cars if you take your time. Purchase the best example you can find (matching your budget) as restoration in NOT cheap. You will spend less money overall on a good car than trying to fix up a beater.
ABS standard.
Greatly improved ECM and programming.
High mount brake light (there's a selling point... ;-)
Automatic air conditioning option. <-- I love this one.
Aluminum heads in the middle of the model year.
Convertible in the middle of the model year.
Lots of detail changes that are not very interesting.
The '82 - '84 Corvettes had throttle body injection, not carburetors.
One problem with the evil combination of old cars and low mileage is that they always have major problems when they finally get running again. Corvettes don't like to sit for long periods of time. Connections corrode and gas goes bad. A friend of mine had mice eat up his wiring.
There's a lot of reason ,when you serch along a one decade generation car,to go straight to last MY,reason why it's obvious, last MY assimilates all improvements that went through 10 years of production and road testing.
In this case,C4 at the end of L98 power plant (1991) shows us two different air metering system,MAF or SD(speed density),MAF is a expensive sensor to replace ($300), it lasted on L98 untill 89,SD uses a MAP sensor that is cheap ($60),if you have to replace parts this informations are important.
ABS option is an important feature to consider,when you'r breaking a 3500lb sport car...it comes in 86...
Better flowing aluminum heads,from late 86....
New 165 ECM in 86',this unit was upgraded from 160 baud to 9182 baud transfer data rate...
In 1987,the old TH700r4 transmission unit was fully upgraded and was re-designated 4l60,Trans-rebuilder never choose an early case to start a rebuild...
In 1990 interior's car was upgraded to a mordern style,if you compare a 89' interior design to a 90 ,89' seems prehistoric
So ,in my opinion,if you like an early 80' style C4 go with an 89',if you like a midle-restyling car,betwen old 80' and last LT1 generation choose a 91'
Again on the topic,choose an 86' at least,new ecm,new heads,abs,...softer suspension ...an example 85 burn off module it's discontinued, you can find on Ebay for $ 150!! 86' maf power relais and burn off relais are 12$ cheap china products available everywere...some details are important,btw my Corvette is an 85'...trust on me
P.s this is a famous 165 swap coming from Tihrd Gen
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
this guy starts his swap report with this words:
The ECM that came in my 1985 Z28 Camaro with the TPI motor (VIN "F") is a series 1226870 (870) control unit (car computer). This model was used in the '85 F-body cars with TPI motors, Corvettes, and some 2.8l V6 (VIN "S" and VIN "W") (*Reference*) cars. One major problem when tuning an EPROM for this ECM is that the diagnostic data (ALDL) is transmitted at only 160 BAUD!. This works out to about a 1.25 second interval between the 25 Bytes of data. I have only been able to get about 6 to 8 data samples during a Quarter-Mile DragStrip run which you can imagine does not provide much feedback for tuning. (sample data are at the bottom of the page in PDF format)
The ECM that came in 1986-1989 TPI Fbody's and Vettes is a series 1227165 (165). The ALDL data rate in this model can supply diagnostic data at 8192 BAUD. The (expanded) data stream of 64 Bytes cycles through every 62.5 milliseconds (16 per second) at this BAUD rate.
870 data rate http://www.eecis.udel.edu/~davis/z28...p/870chart.pdf
165 data rate http://www.eecis.udel.edu/~davis/z28...p/165chart.pdf
No matter what you choose.... welcome to the corvette community !
Are aluminum better flowing heads better than cast iron heads?......YES
Is a faster ECM better than a 20 time slower ECM?.....................YES
Is ABS feature a goodie for a sports car like this?.....................YES
Is an upgraded TH700r4 (87) better than early unit?..............................YES
Are 17" stock wheels better than 16"?YES(so you have enough room to add C5 caliper)
Are larger brake disc better than smaller.....................YES
there are lots of things not mentioned...I repeat,i have an 85,but when i bought it only thing i know about Corvette was they'r fast...Now,knowing much more i'd buy an 89' or a 91 SD in the L98 range.
