1990 fuel regulator question
Old Oct 29, 2011 | 02:23 PM
mypantera's Avatar
mypantera
Default 1990 fuel regulator question
I am in the process of replacing my injectors with a set of Bosch III from FIC and came across a deranged site. The otherwise tick looking fuel regulator has a screw placed in the center of the top. Is there any reason this would be there? It turns easily and doesn't look like a bolt the Gm would of used?.. Any idea why it's there? Trying to determine if i should replace this or if it's ok as is?.
Old Oct 29, 2011 | 02:54 PM
navy_vette's Avatar
navy_vette
It looks like some sort of jerry rigged adjustable fuel pressure. I wouldn't trust it. Get a new one before you end up throwing fuel all over the intake.
Old Oct 29, 2011 | 02:56 PM
mypantera's Avatar
mypantera
thats what I was thinking too.... anyone have a good cover?
Old Oct 29, 2011 | 03:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thats done all the time (modding a stock one) its lasted this long?
If its not leaking leave it be. May have to adjust it once its running.
Old Oct 29, 2011 | 03:35 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
That is the worst place to get a fuel leak. Get a new adjustable regulator.
Old Oct 29, 2011 | 06:33 PM
Bubba91's Avatar
Bubba91
I have a BBK on mine and am happy with it, but most people will say that the Holley unit is the best one. I have to admit that the Holleys look really nice.
Old Oct 29, 2011 | 08:19 PM
leesvet's Avatar
leesvet
LOL....
the smell of fear....or is that gas?
This is a DIY adjustable that someone with a brain made and saved himself $85 for the EXACT same thing without paint...
The store bought regulators are identicle. Adjusting screw threaded into the cap where it limits the travel of the disc that is actuated by the diaphram as it reacts to changing vacuum/pressures and allows more/less fuel to pass.
as long as the screw is stable and not about to fall out, there is no danger...no more than any other regulator. When an adjustable leaks internally it usually goes out thru return since thats there and easier than leaking past the threads of the screw.
The 'bought' regulators do not have any seal in that screw...its the same thing, just ugly.
Old Oct 29, 2011 | 08:29 PM
rodj's Avatar
rodj
Looks like the expensive aftermarket, black anodized, alum ones leesvet mentions ;
except the owner has replaced the fancy adjusting screw it came with
Old Oct 29, 2011 | 08:32 PM
rodj's Avatar
rodj
Even that is fail safe
if the screw falls out you are just back to stockish fuel pressure
Old Oct 29, 2011 | 11:22 PM
mypantera's Avatar
mypantera
Thanks everyone. I was worried when I first seen this however it was working just fine. I may put a nut on there to help lock it place.
Old Oct 29, 2011 | 11:36 PM
leesvet's Avatar
leesvet
Then it will be exactly like the $85 store bought reg top....
......except for one major difference.
You have $85 in YOUR pocket instead of somebody selling a part that you don;t need. That'll happen sooner or later. Do what you can to make it later...
Good Luck with your car !
Old Oct 29, 2011 | 11:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
Unless its super loose just let it be it shouldnt move on you.
To 1990 fuel regulator question
