Fuel injector failure
Old Oct 31, 2011 | 06:47 PM
WBZ's Avatar
WBZ
Default Fuel injector failure
I have been having a bit of trouble with my 91 C4. Changed the fuel filter and Fuel pump. It runs now but not very well. My mechanic just called to say I have some injectors that are bad. He says about $80 each for Bosch etc. Corvette connection has them for $82 for delphi. They also have accel 24 LBS/hr for $319 for a set are these the same thing, He mentioned that there are cheaper options but you get what you pay for. I don't plan to sell the car and I want to do it right. I might add that my is not driven every day and some times is parked for weeks at a time which may be rough on injectors.
Old Oct 31, 2011 | 06:53 PM
dan_t's Avatar
dan_t
I've just posted information for someone else so I'll do a copy for you. And I will say that for our application you don't get better than the BOSCH III's.
You want to contact these people....
http://fuelinjectorconnection.com
Very good reputation and can supply the injectors and gaskets you will require.
I would you'll be pointed towards these.
Injectors $189
http://fuelinjectorconnection.com/sh...&productId=166
Gaskets $30
http://fuelinjectorconnection.com/sh...&productId=172
Old Oct 31, 2011 | 07:17 PM
blackbear bob's Avatar
blackbear bob
with everything Dan just posted. Jon Rocks.
Old Oct 31, 2011 | 07:54 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
A good Vette mechanic should know about Jon. Unless he works at a Dealership or is relying on past knowledge.
Old Oct 31, 2011 | 08:32 PM
WBZ's Avatar
WBZ
Thanks for the information guys. I will call him tomorrow and see what he recommends. My mechanic worked at a dealership for a number of years and now has his own small shop. He seems to know the engine, he says he had a Trans Am with a L98.
Old Nov 1, 2011 | 10:21 AM
WBZ's Avatar
WBZ
Called and talked to Billy, he set me up with a good deal on a set of Delphi injectors and gaskets with shipping $429. They should be here by Thursday. Thanks again for the inforrmation, hope I can help you sometime!
Old Nov 4, 2011 | 02:48 PM
WBZ's Avatar
WBZ
Update........
Injectors and gaskets arrived yesterday afternoon. I took them to the mechanic and got my car back this morning. Runs great, I think the problem is solved. Cost of entire project for parts and labor was $604.
At a small additional cost I also now have A new water pump and belt fresh anti-freze and Mobil 1 synthetic oil. Next stop, the tire store
Old Nov 4, 2011 | 03:02 PM
engle1147's Avatar
engle1147
Originally Posted by WBZ
Update........
Wow - you did get a super great deal at $175 for a injector labor on a TPI
It is a good idea to check the tire(s) "date codes" on the new tires before they stick 'em on the rims. See thread below if your unfamilar with this.
http://forums.corvetteforum.com/c4-g...is-to-old.html
Old Nov 4, 2011 | 04:20 PM
WBZ's Avatar
WBZ
Yes I started that thread also, I sure am learning a lot here
To Fuel injector failure
