Will my diff survive?
Old Nov 3, 2011 | 01:55 AM
Rodney_Gold's Avatar
Rodney_Gold
Default Will my diff survive?
1986 Vette , auto , 3.54 rear gears in a Dana 36.
700r4 has been bulletproofed/shift kit and apart from headers and a free flow exhaust + ratio change , no other mods.
I am planning on dropping in a 400 cu inch motor , old school carburetted with a mild solid roller cam , edelbrock heads or the like , nothing too radical , just some more grunt and power over the 245 hp wimpy motor. I'm not planning on doing any racing barring maybe a run at the local dragstrip just to see what times I can do. All I really want is to make the car into a "road warrior" , something you can go out with and be a hooligan in.
My question is , is the Dana 36 strong enough to take the torque of a 400 ci motor.
Old Nov 3, 2011 | 02:08 AM
87 vette 81 big girl's Avatar
Its a MAYBE.
Depends how hard You hookup off the line.
A built up SBC 400 ci engine can make over 600 ft/lbs of flywheel torque with modern cylinder heads, correct chosen camshaft, ect.
Switching to a modern synthetic gear oil in the Dana 36 will help durability some.
If it was my car, I would use only Royal Purple 85-140 W gear oil in your application & intended usage.
Redline Shock Proof Gear oil is very good too.
But I have found through my own long term testing,
Royal Purple 85-140 W is superior still yet today.
Brian
Old Nov 3, 2011 | 03:44 AM
vetteoz's Avatar
vetteoz
Originally Posted by 87 vette 81 big girl
Its a MAYBE.
So long as your tires spin probably be alright.
If you start getting traction then bets are off
Old Nov 3, 2011 | 07:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
Drive it and dont worry about it.
Old Nov 3, 2011 | 07:08 AM
gerardvg's Avatar
gerardvg
The half shafts are the weak point, i have twisted a pair recently.
Have had some steel ones made and so far so good
To Will my diff survive?
