what is normal operating temp?
These cars run hot because it aides in the emissions process. Kindofa carbon incinerator.
Not to mention the bottom-feeding air intake.
Welcome to the forum, you'll make a lot of friends here as well as learning much and more about your car.
Second, learn to use the Search function. Temps have been flogged more than you can ever dream.
Are you basing your temp readings on the analog temp gauge?
260 would only be if the needle is completely pegged up against the gauge stop.
The gauge does not have a linear scale, so it next to impossible to tell what the exact temp reading is.
As long as the needle isn't into the shaded area on the gauge, it's not over heating.
What does your digital temp gauge read?
If your digital gauge reads 240-245 while moving down the freeway, then you have a cooling problem (either blocked airflow across the radiator, or blockage in the coolant flow).
Normal temps for the digital gauge would be in the 192-200 range while moving at any speed over 35mph.
While stopped at idle for any length of time, the temp be in the 210-230 range.
Use the digital temp gauge, that analog gauge will just scare you.
