86 headlights and cluster
Old Nov 5, 2011 | 09:54 AM
golfnstuff's Avatar
golfnstuff
Default 86 headlights and cluster
Having a bad day working on the vette. The cluster lost it's ground, again. I have good ground to the cluster so it's between circuit boards. Having a terrrible time removing the connectors so I gave up for now. Now I have a problem with the headlights. If I push the switch all the way in to close them, they close fine but the headlight motor sounds like its still trying to close. Really loud. I can postion the switch just right and get them closed with out the noise but if I push the switch just a little more, the motor driving sound begins again. Any ideas about the headlights? Adjustment needed? Replace switch. All was fine until I disconnected the battery while working on the cluster.
