Driveline Vibration
Now then, new tires (Continentals) road force balanced, new rear hubs. All 6 UJoints appear to be in great shape, no obvious slack and no signs of rusty powder. Tried different tire pressures, from 30psi to 35psi.
Just spent the last 1.5 hours reading threads about vibration and the common thread in all of them is that this is a common problem, but 90% of the threads do not end with the original poster explaining how it was fixed.
Have had the car 7 months and it has vibrated slightly since I got it and it is now getting worse. The vibrations are cyclical, in that they come and go in increasing and decreasing amplitude, like a sine wave.
I have thought about shocks, new UJs, rear wheel geometry, but want to see if any of you guys who have had this problem can shed some light?
Cheers (not holding my breathe though
I have had brand new tires do this, there was a problem with the manufacturing and i got another 4 new ones.
Best bring the vette to a tire shop and get the wheels balanced, it is easy to loose the adhesive weights. They will tell you if there is a problem with the tires.
Also check if the vibration is worse with higher pressures, that will show up out of round tire problems.
The job can be done at home. They're plenty of posts with pictures.
I've done it twice on my 87. The last time I didn't see any dust either.
The outer one will show the wear first.
Js
I will go and get the wheels double checked. When I replaced the rear hubs it reduced the vibration somewhat, but it is still there. I did check the UJs and they felt rock solid, no play at all.
I will look and see if the drive shaft balance weight is still there. Not sure if any of the POs ever pulled the shaft. Everything looks original down there, but who knows??
Here's a dumb question...where do I take the car to have the drive-shaft balanced? Will my local Chevy dealer be up to it, or is it more a specialist job?
I had very similar symptoms in my '94 six-speed car, and the cure turned out to be a replacement front yoke on the driveshaft, and a new tailshaft bushing (and seal, too, of course).
I don't recall the exact numbers for acceptable lash between the yoke and tailshaft bushing, but Bill Boudreau at ZF Doc can tell you. If yours exceeds this limit, there's an excellent chance that addressing this will solve your problem.
Good luck. Let us know how it turns out.
Live well,
SJW
My driveshaft was very badly out of balance due to an auto to ZF6 swap so I noticed a huge improvement in high speed stability. I've had it up to 120mph and it feels like silk. Remember the driveshaft turns 3-4 times as fast as the half shafts so even a little imbalance is annoying.
Just wanted to bring this thread to a logical end
