Sagging to driver's side
Old Nov 17, 2011 | 08:56 AM
StephensblackL98's Avatar
StephensblackL98
Default Sagging to driver's side
My car, a '93, sags to the driver's side. I've done a visual inspection of the front and rear, and can't see anything obviously wrong that would allow the car to tilt as it does.
Best guess, is it the spring in the rear?
Thanks, not much to go on, I know, but I appreciate anyone's guess or sending me in a direction.
Old Nov 17, 2011 | 09:08 AM
cv67's Avatar
cv67
St. Jude Donor '05
Spring would be my guess.
Just a guess though.
Old Nov 17, 2011 | 10:24 AM
383vett's Avatar
383vett
How much do you weigh?
Old Nov 17, 2011 | 10:48 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Do a closer inspection on the springs.
Be careful, when they start to delaminate the splinters can be painful.
Old Nov 17, 2011 | 11:19 AM
engle1147's Avatar
engle1147
How uneven from side to side is the car?
I don't know how true it is but from what I've understood from reading what has been posted over and over here on CF in the past is that these cars were not "level" from the factory - the passenger side of these cars was designed to sit a bit higher than the driverside...something about the "crown" of the road makes it sit "level" and what not....so maybe yours does not "sag" so much.
Old Nov 17, 2011 | 11:29 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
But the splinters ARE PAINFUL!!!! No "can be" in this situation.
You might also consider doing an adjustment to the link bolt on the sagging side after making sure the spring is in good condition.
Old Nov 18, 2011 | 11:04 AM
DanZ51's Avatar
DanZ51
I call BS on that theory. I've been to Florida, your roads have no crown. And what Corvette was designed to be driven in the SLOW lane?
Factory alignment specs make no difference for right or left side. And the springs are not marked drivers and passengers side. The manufacturing complexities abound, while the actual benefits are questionable. I call this myth: busted
Old Nov 18, 2011 | 12:00 PM
engle1147's Avatar
engle1147
Dan,
WTF do the roads in Florida or a SLOW lane of traffic have to do with what I posted?
Old Nov 18, 2011 | 12:27 PM
RWDsmoke's Avatar
RWDsmoke
My frame was twisted a little but I still leveled the body. Use a floor jack on the front center to lift the front off the ground. If the car levels itself in the rear it is the front suspension that is causing it. I had to shim one side of the front spring to level mine in the rear. Then shim the hood and adjust the front bumper to level the front. Easier and cheaper than trying to straighten the frame.
Old Nov 18, 2011 | 04:52 PM
bitsa85's Avatar
bitsa85
Was your car in a accident? Or was it just metal Fatigue
To Sagging to driver's side
