Hey dude,
When you removed the air pipes and emssions parts,did you use any washers to replace the bracket that originally went on the waterpump?
Im speaking of that black metal tube with a round end and a filter inside(diverter pipe?) that goes on the water pump.
I wasnt sure if I would have a little alignment problems with the a/c brackets and etc to the waterpump when i yanked all that stuff off,so I put washers there the same thickness as the black air pipe bracket.
Just wondering if you did this or if it isnt a problem on your car.
ok cool...wasnt sure by removing it,you would need something there.Its been a while since I took mine off and kept thinking by removing the pipe youd need something in place of it to preserve alignment of the brackets and nuts..If it went on the very front then thats not a problem.
