third brake light bulb #
Old Nov 10, 2011 | 12:40 PM
ctrain22's Avatar
ctrain22
Default third brake light bulb #
Can someone tell me what number bulb the third brake light uses for an 88 convertible? Are they the same as the cluster bulbs?
Old Nov 10, 2011 | 03:10 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I believe they are halogen and therefore about $7 EACH. I had to replace them all on my 89 coupe.
Old Nov 10, 2011 | 03:45 PM
engle1147's Avatar
engle1147
I'm pretty sure the 'vert takes this one for the third: http://shop.advanceautoparts.com/web...RPLAMPAMS_____
Old Nov 10, 2011 | 04:22 PM
Chuck Tribolet's Avatar
Chuck Tribolet
At least on '87, the verts and coupes use different bulbs. The coupe
bulb is a bit of an oddball -- nobody makes an LED for it.
I'm pretty sure they owner's manual lists the bulb numbers.
When removing the light assembly, put a shop towel between the wrench
and the targa bar. And be sure to pull the rear window up all the way to
get more wrench clearance.
Old Nov 11, 2011 | 12:05 AM
Cliff Harris's Avatar
Cliff Harris
Not true about an LED version of the coupe high mount brake light. My car has one. I laid out a PC board but the prototype PC board house wanted over $600 for 10 (minimum order) two-sided with plated through holes and silkscreen. In retrospect, I could have left off the silkscreen and made it one-sided, which would have been much cheaper.
I checked Digi-Key and bought the brightest red LEDs they had. It was about $45 for 100 and I used 64. I went that route because I didn't know how bright they needed to be. Now that I know better (they're very bright), I could have bought some much cheaper high brightness LEDs.
I took some PC board material I had and routed out the copper with a Dremel tool. It's been on my car for several years and I never have to worry about replacing those expensive halogen lamps. Here's a comparison between the 4 halogen lamps on the top and the LED version on the bottom. I had to hold the camera off axis because it blasted it with light and overloaded the image sensor. The LED version is actually brighter than the halogens. One advantage of the LEDs is that they come on instantly, giving a little extra margin of warning to wake up the guy behind me.
Old Nov 11, 2011 | 10:20 AM
Chuck Tribolet
Some folks (inc me) have used LED strip lights.
But there's nothing that's plug and play.
Chuck
Old Nov 12, 2011 | 08:17 AM
C409's Avatar
C409
......... I bought halogen bulbs at the home center in the outdoor walkway light section ... about $7 for a pair .........
Old Nov 13, 2011 | 04:24 PM
ctrain22's Avatar
ctrain22
but what number bulb? I thought they were halogen, but are they the same #791 like the dash cluster?
Old Nov 13, 2011 | 07:24 PM
rodj's Avatar
rodj
even cheaper
JC Type G4 Bi-Pin Base Halogen 12V
Same bulbs as used in 12V halogen desk lamps
Just need to tweak the pins slightly to fit Vette
10 for $6.50
http://www.ebay.com/itm/10pcs-Haloge...item4841a6f04f
Old Nov 13, 2011 | 09:24 PM
Chuck Tribolet
Incandescent bulbs, halogen or otherwise, take a car length or two at
freeway speeds to light up. LEDs take zero time. No brain decision.
Chuck
Old Nov 14, 2011 | 08:16 AM
C409's Avatar
C409
..... It takes about five minutes to open the light up and pull a bulb out ... there should be a number on it ... and while its open try your dash bulb to see if it fits ..................
Old Nov 14, 2011 | 10:56 AM
engle1147's Avatar
engle1147
Found this using the CF "search" function - no part number for the convertible but installation/removal instructions are included:http://forums.corvetteforum.com/c4-t...ht-1988-a.html
Perhaps these vary for different years but of the convertible brake 3rd brake light I've seen/changed you just need to remove the license tag reach up and change out the single bulb.
Old Nov 14, 2011 | 09:47 PM
ctrain22's Avatar
ctrain22
Well, for future reference there are three small halogen bulbs, #891 at your local auto parts store. Same bulbs as the dash cluster. Take off license plate and reached in to get to the two nuts that hold the light on the car. Outer bezel comes off and the light comes out from behind and through the license plate area. Two screws hold the bulb bar to the light. unsrew the two screws and replace the bulbs. By the way, these little bulbs do not have numbers on them that I could find. Too small.
Old Aug 26, 2013 | 05:48 PM
WOLF ECHO's Avatar
WOLF ECHO
Active Streak: 90 Days
For those with early-C4 verts ...
I went to my local auto parts store and asked for a replacement bulb for the third brake light. The person sold me an #891. When I was finally able to get to the bulb in the car, it turned out to be an #1156! Sounds like:
coupes use three (3) #891's in the housing above the rear glass.
verts use one (1) #1156 in the housing in the rear fascia.
I'm heading back to the parts store to get the right bulb. I'm hoping they sell LED versions of the 1156, 'cause I don't want to have to do this again in my lifetime. What a PITA!
Old Aug 26, 2013 | 10:48 PM
SeeFourSix's Avatar
SeeFourSix
http://www.sylvania.com/en-us/applic...n.aspx#fldYear
To third brake light bulb #
