just flat quit!!!
Old Nov 15, 2011 | 01:43 AM
coastalgal's Avatar
coastalgal
Default just flat quit!!!
i have a 96 lt1 with about 80k miles... it is my first vette... and i am attempting to do the wrenching...
i havent received the manual i ordered yet... that being said...
i went to leave home tonight... cranked her over and heard a thud... but she ran ok... got about 5 miles from home... and the car just quit... i had lights... but when i finally came to a stop... i could turn her over... but it was like she was not getting gas...
a friend suggested it might be the fuel filter...
another friend suggested the fuel pump... but then said because of the thud perhaps the timing chain? just looking for the easiest solutions to check first... want to exhaust the simple things first...
suggestions welcome... wont have the time to check her out til next weekend... but would help if i have an idea where to look...
Old Nov 15, 2011 | 02:06 AM
DMheart's Avatar
DMheart
I'd start with looking for a trouble code that will hopefully lead you in the right direction.
Depending on how deep that "thud" sounded, I'd hate to think that could be something very serious.
Old Nov 15, 2011 | 09:05 AM
sailorsteve's Avatar
sailorsteve
A timing chain failure at 80K is highly unlikely. Also, the engine would not turn over, as there would be valve-to-piston interference.
Basic diagnosis for no-start is to squirt a sniff of ether into intake while cranking to see if car tries to start, if so, suspect a fuel delivery problem. You should hear the fuel pump (it's behind you, in the tank) run for a couple of seconds with the key on before cranking.
If no reaction, check a plug wire for spark while cranking by grounding to the block, or using an induction-type timing light. If no spark, could be the thud was the Optispark's farewell.
I agree that you should pull any codes, you need an OBDII code reader to do it. Some auto parts stores will do it for you, no charge.
Old Nov 15, 2011 | 11:06 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
There are several no-start troubleshooting pages in the factory service manual. Start there!
Or just throw parts at it.
ICM
Coil
Harness from Opti to ECM
Plug & coil wires
Fuel filter
fuel pump
Opti
ECM
etc.
etc.
etc.
Old Nov 17, 2011 | 01:23 AM
coastalgal's Avatar
coastalgal
the book has been shipped... thanks for the input... i cant get it to an autoparts store i live in the country... and i had her towed home... ill check the fuses and relays first then check for the things i can check like fuel delivery...ect... if that fails perhaps pay the local mechanic to come out here and diagnose the problem... however... i want to be the one to fix it...
i am hoping to take a trip in her to southern california next spring and i dont want to get caught in the middle of nowheresville afraid to work on her...
thanks for the suggestions... ill do what i can do...
Old Nov 17, 2011 | 01:28 AM
93VettePilot's Avatar
93VettePilot
Hang in there. Remember your driving a 15 year old car.
Old Nov 17, 2011 | 01:39 AM
coastalgal's Avatar
coastalgal
thanks ... occasionally i need that... she is just so much fun to drive i forget that...
Old Nov 17, 2011 | 11:00 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Shoot, I didn't read all of your first post - I apologize.
Steps:
Check fuses, you are looking for INJ 1, INJ 2 and the one for the ECM (I forget what its called and my FSM is at home)
Get a fuel pressure gage, hook it up to the valve near the fuel pressure regulator, turn the key on and look for pressure (should be north of 40psi), turn key off and leave it hooked up for a couple hours, note how fast it lost pressure.
Bang could have been excess fuel from a leaky injector.
I know when my lifter got into the timing chain and broke it there was not a lot of noise
Old Nov 17, 2011 | 01:31 PM
DMheart's Avatar
DMheart
"... lifter got into the timing chain..." ???? How the heck would that happen???
About your cranking but won't start ....
Is the cranking steady or does it seem to lope as if crippled?
Old Nov 17, 2011 | 01:43 PM
coastalgal's Avatar
coastalgal
it cranks hearty like any other time it has started... i believe if it was getting fuel it would start...
Old Nov 17, 2011 | 01:44 PM
coastalgal's Avatar
coastalgal
thanks i will check them first...
Old Nov 17, 2011 | 05:11 PM
DMheart's Avatar
DMheart
A simple test light will help you determine wether or not your injectors are receiving their "turn on" pulse.
Old Nov 17, 2011 | 06:01 PM
pcolt94's Avatar
pcolt94
Is there gas in the tank? Sounds stupid but the gauge can be off that much if there is corrosion on the sending unit. If you don't know the car yet then you can't be sure. Why do I say this, it happened to me the day I bought my car (ran out of gas). Just something to consider.
Moving on, when you turn the key to ON (no crank) you should hear the fuel pump run for 2 seconds. Pump is in the tank in the rear so listen for it there. If there is no sound, there is a pump problem. I know you don't have a pressure gauge yet.
This is hard to describe but if the pump sounds too loud, there might be no gas in the tank.
The only other basic thing is suggest to do is to check for spark either off the coil or at a plug. At least that way you might know if you are in the spark or fuel area.
Don’t get to complicated out of the gate until you do the basics first.
Old Nov 17, 2011 | 08:32 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Do a search for my user name - I even took pictures.
There is an oil return hole at the front of the block that was just the right size for the lifter to fit.
Old Nov 17, 2011 | 11:55 PM
coastalgal's Avatar
coastalgal
thanks... saturday afternoon i will try these things out... i have a one year old m-f during daylight hours... i just cant get her to cooperate when i want to work on the car...LOL
Old Nov 18, 2011 | 12:31 AM
DMheart's Avatar
DMheart
Oh man.... that one had to hurt.
Old Dec 6, 2011 | 12:28 AM
coastalgal's Avatar
coastalgal
okie dokie if you are interested here is what happened...
there was a hose connector that had come loose... it was dripping onto the electronics or distributor... and was shorting it out... when it dried up it started immediately but then cut out after about 5 minutes... it was then we figured out what was happening... thanks for all the help chasing the problem however...
To just flat quit!!!
Old Dec 6, 2011 | 11:06 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Maam - you need to plan on a waterpump and opti change at some point in time.
Even though the opti dried out I garundumtee you it wil fail again and won't return.
The optical sensor is the important part and getting water in there shortens its life.
Glad you got it running for now!
Old Dec 6, 2011 | 11:15 AM
pcolt94's Avatar
pcolt94
Good work, glad you found it. Guess it was a spark problem after all. Hopefully the opti will make a full recovery and will not carbon trace in the cap.
Old Dec 6, 2011 | 01:12 PM
coastalgal's Avatar
coastalgal
i have replaced the waterpump recently... guess i need to consider replacing the optispark... ugh!!! i was hoping to take this car to california early next year... hmmm
