60k mile DIY checkup
Old Nov 15, 2011 | 10:28 AM
89C4RedRed's Avatar
89C4RedRed
Default 60k mile DIY checkup
I just bought my car with 60 miles on it, and I am wondering what I should check on the car? the original owner says everything is stock same wires, brakes, etc. Wondering what I should do should I get fluids flushed, new brakes, wires, dizzy cap etc. thanks, any feedback would be greatly appreciated.
Old Nov 15, 2011 | 11:27 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would recommend changing all the fluids and filters. That and give everything a good look over and you should be good to go.
Old Nov 15, 2011 | 01:10 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Include brake fluid and check the bearings along with everything above
Old Nov 15, 2011 | 03:27 PM
sailorsteve's Avatar
sailorsteve
Even though the miles are low, it's an old car. I would also check rubber hoses under the hood, see if any are spongy or brittle. How old are the tires? (There should be a date code on them)
Old Nov 15, 2011 | 05:29 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Yes, all of the above, plus ALL fluids, serp belt, rad hoses, plugs. Also clean throttle body and the area in between the AC condenser and the rad. Consider changing rubber bushings, ie, sway bars, end-links, dog-bones, rear camber rods etc.
Old Nov 15, 2011 | 08:21 PM
SunCr's Avatar
SunCr
Is it 60 or 60,000? Your title says 60k. If 60, I'd get new tires or you can check the sidewall for their age. If 60,000, probably half of what came on the car has all ready been replaced.
Old Nov 15, 2011 | 08:42 PM
89C4RedRed's Avatar
89C4RedRed
Sorry, meant 60,000. Ok thanks everybody, I will inspect all hoses and misc items and change out fluids. Thanks.
To 60k mile DIY checkup
