Spare Relay in Tool Box
Old Nov 15, 2011 | 03:55 PM
buzzlightyear's Avatar
buzzlightyear
Default Spare Relay in Tool Box
Of all the relays in a C4 which one would you keep a spare for just in case. Is there one relay that can multi task for a number of purposes? Thanks
Old Nov 16, 2011 | 05:13 AM
ddahlgren's Avatar
ddahlgren
I think many are year specific though not sure of that to be honest. If this is something to just get you home with a failed relay you will certainly need enough tools to get to the relaysif like my 91 they are buried under the dash and behind all sorts of stuff so not a 5 minute fix you will be there a while digging to get to them. if only a temporary thing to get home a jumper wire with a couple of 1/4 inch spade connectors and #10 wire to jump from line to load terminals will make the device run depending on year some relays use a metra-pack 280 male terminal instead of the 1/4 inch spade so you would have to check the relays ahead of time to be sure you have what you need.
Old Nov 16, 2011 | 07:51 AM
WW7's Avatar
WW7
On my 89 the MAF relay, burn off relay, and the Main fan relay , are all the same. On your car Im not positive if they are the same or not..WW
Old Nov 16, 2011 | 08:06 AM
JackDidley's Avatar
JackDidley
87 some have different part #s but will interchange anyway.
Old Nov 16, 2011 | 08:15 AM
sailorsteve's Avatar
sailorsteve
If you carry spares for all the relays, you will guarantee that something else will fail. And, as stated, diagnosis and repair on the side of the road is not so easy. If you are concerned about getting stranded, The best things to carry are a cell phone and AAA gold card.
Old Nov 16, 2011 | 09:40 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
There is no way you could carry enough spare parts to cover every possibility of what "might" break.
Cell phone and a credit card is all I carry. If/when the car breaks down, I'll deal with it then.
Sure not going to worry about what spare parts I may or may not need.
When I leave for extended trips, my wife makes sure she uses up all the extra room anyway.
To Spare Relay in Tool Box
