pulled timing chain but forgot to align marks
Old Nov 17, 2011 | 09:29 PM
jhill133's Avatar
jhill133
Cruising
Default pulled timing chain but forgot to align marks
doing cam change on l98 and pulled the cam forgetting to align marks or mark the position of the cam to crank gears. how can i get this back in right and on time. thanks
Old Nov 17, 2011 | 09:37 PM
JackDidley's Avatar
JackDidley
Rotate the crank so the dot is at 12 oclock. The cam dot at 6 oclock. This will have cylinder #6 at tdc compression stroke. Rotate the crank 1 turn, the dot on the cam gear will be at 12 oclock, cylinder #1 will be firing.
Old Nov 17, 2011 | 09:42 PM
cv67's Avatar
cv67
St. Jude Donor '05
If you happen to have 3 dots on the lower gear use the middle one.
They only go on one way as there is a keyway the gear slips over.
To pulled timing chain but forgot to align marks
