AUX FAN
Old May 7, 2002 | 08:37 AM
rmedina's Avatar
rmedina
Default AUX FAN
Does the Aux Fan kick in when the AC is on?
Thanks,
Raul
Old May 7, 2002 | 09:19 AM
BETA's Avatar
BETA
Default Re: AUX FAN (rmedina)
Yup :yesnod: At least on my 91
[Modified by vette5, 7:03 PM 5/7/2002]
Old May 7, 2002 | 10:58 AM
87SAM's Avatar
87SAM
Mine does not, well, as much as I can remember :confused: I am sure is does not when the main comes on because of temp...
Old May 7, 2002 | 12:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
https://www.corvetteforum.com/techti...D=79&TopicID=2
Old May 7, 2002 | 12:55 PM
JonM's Avatar
JonM
The main SHOULD come on when you turn the AC on...I don't know about the AUX fan because I don't have one.
Old May 7, 2002 | 02:18 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: AUX FAN (vette5)
Yup :yesnod:
Dave, Before you answer, you need to find out what year. On Raul's '87, the aux fan is in front of the radiator controlled by a temp switch in the driver's side head. It does not come on with the A/C.
Old May 7, 2002 | 04:36 PM
rcolling's Avatar
rcolling
Default Re: AUX FAN (Ray Quayle)
Ray has it right. The Aux fan comes on at some ungodly high temp. I can't remember exactly but around 240 or so. Main comes on with AC or at around 228.
Old May 7, 2002 | 07:14 PM
rmedina's Avatar
rmedina
Default Re: AUX FAN (rcolling)
Thanks Guys..
Raul
Old May 8, 2002 | 07:17 PM
dlmeyers's Avatar
dlmeyers
My 90 has the dual fan set up, stock and both fans are supposed to come on with A/C ON. Now, without A/C ON, fan operation at idle is temp dependent. Just replaced my primary fan (top left) last weekend cause it was dead (both relays checked good). Those fan motors are exposed to lots of dust/ dirt and with 63K, must have been time. Elected to replace the second fan motor, cost per motor was around $40. All is well.
Not sure how 884-89's operate.
To AUX FAN
