Engine Coolant Temperature Sensor (ECT)
Old Nov 20, 2011 | 03:46 PM
VA50th's Avatar
VA50th
Default Engine Coolant Temperature Sensor (ECT)
96LT1 auto
What is involved with changing the ECT?
My digital readings have been higher than 'normal'. Fans still come on, but I've noticed over the past 2 weeks that driving around town, the temperature levels out at about 205-208. No codes or warning lights.
Maybe the thermostat needs replacing?
Thanks!
Old Nov 20, 2011 | 04:02 PM
STL94LT1's Avatar
STL94LT1
Doesn't sound like a bad CTS.
Old Nov 20, 2011 | 04:19 PM
VA50th's Avatar
VA50th
another thing I noted...about 30 minutes the temp seem to settle down. I also noted that when the analog pointer is at 185 (mid level) the digital reads about 20 degrees higher..
maybe the thermostat is slow to open
To Engine Coolant Temperature Sensor (ECT)
