HEI Coil
Old May 7, 2002 | 11:21 AM
Mr. Sharky's Avatar
Mr. Sharky
Default HEI Coil
When and under what circumstances should you change your coil? Should it be every time you change plugs and wires or is there a way to determine if the coil is faulty and warrants changing?
Old May 7, 2002 | 11:37 AM
poppy's Avatar
poppy
Cruise-In III Veteran
Default Re: HEI Coil (Mr. Sharky)
Take it to Autozone to be tested, guaranteed to by one then. It just seems like everytime I take some to be tested there they find it tested bad. Go figure. :rolleyes:
Oh My's Avatar
Oh My
You can take the coil out of the distributor and take it to a Parts store, where they can test coil for proper resistance.
Old May 7, 2002 | 01:14 PM
jfb's Avatar
jfb
Check your spark waveform on an ignition analyzer to determine if the coil needs replacing. Otherwise keep on truckin.
Old May 7, 2002 | 07:56 PM
Rich B.'s Avatar
Rich B.
Is the wire part of the coil (the black lump in the middle) supposed to be firmly fastened to the outer plates (the steel "O" around the black lump)???
Mine is slightly loose, buts works fine...
(I apologize for the technical terms)... :D
To HEI Coil
