dynomax VT mufflers
Old Nov 23, 2011 | 09:28 PM
Cavi's Avatar
Cavi
Default dynomax VT mufflers
The PO put flowmaster 40 on my car, straight from the cats, just two straight pipes, no resonator, or crossover. I now have a stock resonator which I will install but I still want the flowmaster 40s gone. I am thinking of the dynomax VT, they have an internal valve which in theory should cut down on the droning without cutting the good throttle sound.
Has anyone here used them?
Old Nov 23, 2011 | 09:33 PM
96 lt-4's Avatar
96 lt-4
I have not used them but my concern would be the spring on the valve coming off or something becoming loose and rattling over time.
If you went that route I would do it w/o the stock resonator and see if it is quiet enough.
The stock resonator is quite restrictive.
The theory is great and sounds wonderfull on the C6 vette.
Old Nov 23, 2011 | 09:46 PM
Cavi's Avatar
Cavi
I was actually going to install the stock resonator with my flownasters first to see bow it sounds
Old Nov 23, 2011 | 10:40 PM
Marv02's Avatar
Marv02
I 2nd that about the Flapper valve and spring rusting breaking and rattling.
I just cut Off my Magnaflows and waiting for my 2 chamber mufflers to show up.
The Magnaflows are to Quite for my taste You more or less dont not have much noise at HWY speeds but around town between 35 and 45 MPH they have a Drone to them.
I took a look at the FM 50"s they say those have litttle drone I wanted it to be Loud at Idel and when your foot in it.
My Vett Is my Toy not my DD it was for a couple Months for a while use as a DD I think if I had to use it as a DD all they time I either keeped the MF or went with the FM 50"s.
Old Nov 23, 2011 | 10:41 PM
Marv02's Avatar
Marv02
Are you useing a rear crossover tube they say it helps kill the drone.
Old Nov 23, 2011 | 11:12 PM
llong66's Avatar
llong66
I have dynomax mufflers and love them, they dont have any kind of valve in them or anything but sound great!
Old Nov 24, 2011 | 12:16 AM
cv67's Avatar
cv67
St. Jude Donor '05
The resonator or the 2 into 1 into 2 doesnt need a crossover, already has one of sorts from the factory.
Old Nov 24, 2011 | 08:05 AM
cshuman's Avatar
cshuman
I have them on my 91. Went from my long tubes to a center muffler with a built in crossover back to the rear to the VT's and it is as quiet as stock, no resonance. When you get on it though it sounds great. I had the same set up with magnaflows at the rear and the resonance was bad so I changed to the VT's
I've had them on for about 6 months with no problems, but then again it's not a daily driver.
Old Nov 24, 2011 | 11:05 AM
Cavi's Avatar
Cavi
Cshuman. Did you remove your center muffler when you went to the vt ?
Old Nov 24, 2011 | 11:15 AM
cshuman's Avatar
cshuman
No I left it on. If you wanted to be louder I assume you could install an x pipe in place of the center muffler and just run the VT's at the rear.
Marv02's Avatar
Marv02
Yes the pipes under the car acts like a crossover but the extra rear one also helps out also.
Old Nov 24, 2011 | 11:16 AM
Marv02's Avatar
Marv02
Only the VT have the Valve and spring.
To dynomax VT mufflers
