scratching my head
Old Nov 24, 2011 | 09:36 AM
jesse_c4's Avatar
jesse_c4
Default scratching my head
Ok guys hope you can help with this one. I have a 87 vette coupe and I went out to the garage to start her up and nothing, wtf.
When i put in the key i hear the fuel pump prime and when i turn the key the starter turns but will not start up. I drained the battery trying to start the car I charged it last night. went out this morning and car turns over but wont start.
I took out a plug and checked for spark and yes i have spark.
this is really stumping me because the car ran the other day and started rite up fine ran it for about 15 min and put her back in the garage. . .
Old Nov 24, 2011 | 10:24 AM
Muffin's Avatar
Muffin
Knee jerk reaction is injectors not firing. I suggest two quick tests: first check fuel pressure at the rail. You could have a filter or line plugged. Second use a noid light to see if the injectors are actually firing. Auto Zone has noid lights you can borrow. You did not say if you pulled a plug to see if they were wet. It is possible you have a serious flood condition but I doubt it. Last you really need to get a copy of the FSM. It will guide you through all the steps to pin down a problem.
Old Nov 24, 2011 | 12:47 PM
C409's Avatar
C409
................... Clean the "pill " contacts on the key , and jiggle it in the cylinder ... its likely a VATS issue ........ although you say it is cranking ... could be a fuel pressure regulator diaphragm if its flooding .....
Old Nov 24, 2011 | 04:27 PM
jesse_c4's Avatar
jesse_c4
just came out of the garage and I pulled a plug and i do have spark but they are not wet. then I checked for fuel pressure and nothing. no fuel squirting out like normal. when i turn the key i hear the fuel pump kick on...i loosened the fuel filter and fuel started coming out...but it looks like i have no fuel in the rails...
p.s. thanks for all the comments guys
Old Nov 25, 2011 | 04:35 PM
jesse_c4's Avatar
jesse_c4
Default no fuel ! ??
ok so i tried to start the car today and it still would not start. when i turn the key i can hear the fuel pump kick on but when i try to release pressure on the fuel rail i get nothing out of it. what can you guys add to this. what do you think it is ?
p.s. the gas gauge shows almost 1/2 and i did add a couple gallons of fuel from a jug just to make sure i have fuel...
Old Nov 25, 2011 | 05:57 PM
DPC Racing's Avatar
DPC Racing
Sounds like the fuel pump or filter on pump{in tank ] blocked you need a fuel pressure test gauge to hook to the fuel rail, no pressure but you hear pump run start with pump.
Hope this helps
Old Nov 25, 2011 | 06:00 PM
jesse_c4's Avatar
jesse_c4
Default new fuel filter
I just got back from napa and bought a fuel filter. going down to the garage now... i will let you know if this solves the problem.
thank you for your input
Old Nov 25, 2011 | 11:32 PM
jesse_c4's Avatar
jesse_c4
well the new fuel filter didnt help but I didnt know when the last owner had changed it so at least I know its new. tomorrow is another day... I will be in the garage...
Old Nov 25, 2011 | 11:59 PM
gunnerjuju's Avatar
gunnerjuju
Good luck
Old Nov 26, 2011 | 01:30 AM
ex-x-fire's Avatar
ex-x-fire
Is the security light flashing?
Old Nov 26, 2011 | 09:13 AM
DPC Racing's Avatar
DPC Racing
Did you change the one in the fuel tank? looks like a screen or the one on the frame.I have had the ones in the tank fold up and block pump from sucking.
DPC
Old Nov 26, 2011 | 11:01 PM
jesse_c4's Avatar
jesse_c4
Default fixed my car ~!
I changed the one on the frame...
So i fixed the vette today...
this morning I pulled out the fuel pump from the tank and the rubber hose that couples the fuel pump to the metal hose had split open...simple fix and Im happy as a pig in st** now. put everything back together and she started rite up.. woot woot
Old Nov 27, 2011 | 12:26 AM
gunnerjuju's Avatar
gunnerjuju
Woot woot. Take it out for a nice long ride tomorrow. Good for you Jesse
Old Nov 28, 2011 | 06:04 PM
DPC Racing's Avatar
DPC Racing
Old Nov 29, 2011 | 12:50 AM
joeld's Avatar
joeld
I hope you used submersible fuel line, and not just regular. If not, you'll be doing this again in a few months if not sooner.
Joel
Old Nov 29, 2011 | 02:31 AM
Cliff Harris's Avatar
Cliff Harris
You need Gates 27093. It comes in 1 foot lengths. If you can get it for less than $20 you're doing well. I paid $26 a few years ago.
Old Mar 30, 2012 | 10:04 PM
jesse_c4's Avatar
jesse_c4
i think it was regular fuel line... but I will keep an eye on it and try to get the rite stuff. thanks guys !
To scratching my head
