Nitrous Question with TPI
Old May 7, 2002 | 08:02 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Nitrous Question with TPI
Okay guys I have a question about running a Nitrous system on my 91. I am looking at getting one of the throttle body plates that runs two foggers instead of the spray bars. My question is this if I hook up two solinoids and the appropiate hardware can it be run as a two stage system? I want to do something like 2 75hp settings or maybe a 50 and a 75. Would the 2 foggers being on opposite sides of the plenum cause any problems with running rich/lean on the opposite sides of the foggers, or would the foggers "fog" the mixture enough that there would not be a problem?
[Modified by No Ordinary 91, 5:02 PM 5/7/2002]
Old May 7, 2002 | 10:01 PM
red-y's Avatar
red-y
Default Re: Nitrous Question with TPI (No Ordinary 91)
Nos makes a programable control valve that will allow the kind of setting you want for around $250-300. :seeya
Old May 7, 2002 | 10:23 PM
555ciC4's Avatar
555ciC4
I'm using one spray bar with two stages of NOS. I jet the spray bar for the max, say 125hp. I run a braid hose from the spray bar to a "T" fitting. I had the other two ends of the "T" modified so I can insert NOS jets. Install 75hp and 50hp jets and connect a braid hose to each solenoid. You could use the same principle with the Fogger. Other options are a NOS progressive controller or Nitrous MasterMind :D
[Modified by 555ciC4, 2:28 AM 5/8/2002]
[Modified by 555ciC4, 2:31 AM 5/8/2002]
Old May 8, 2002 | 02:20 AM
vetsvette's Avatar
vetsvette
Default Re: Nitrous Question with TPI (555ciC4)
555ciC4,
Where do you run that beast? I live in southside VA and would like to come see you run sometime.
:seeya
Old May 8, 2002 | 07:27 AM
555ciC4's Avatar
555ciC4
Default Re: Nitrous Question with TPI (vetsvette)
I plan on being at http://www.virginiamotorsportspk.com/ for a race on May 18th.
Old May 15, 2002 | 09:04 AM
555ciC4's Avatar
555ciC4
Whitey,
I'm not going to be at http://www.virginiamotorsportspk.com/ for the race on May 18th. Sorry I'm having clutch problems. :mad
To Nitrous Question with TPI
