Did a open lid mod tonight
Old May 7, 2002 | 08:47 PM
Kevin McGrade's Avatar
Kevin McGrade
Default Did a open lid mod tonight
What a pain in the rear cutting the lid. I used a dremel with about 50 cutoff wheels. I broke just about every one of them too :mad
After that it was a piece of cake, I painted with some high gloss appliance spraypaint and it looks great!! :cheers:
In my opinion it was worth the time. Now i am in search of some rubber u-channel molding to finish the look.
[Modified by Kevin McGrade, 7:48 PM 5/7/2002]
Old May 7, 2002 | 08:49 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: Did a open lid mod tonight (Kevin McGrade)
I took the easy way and just bought an open lid. Pics?????
Old May 7, 2002 | 09:00 PM
Kevin McGrade
Default Re: Did a open lid mod tonight (Alchemist)
I was thinking about buying one also but ....wedding in 5 weeks :cheers:
Plus it was a fun little project. I will snap off some pictures later, it is out on the porch drying :jester
[Modified by Kevin McGrade, 8:01 PM 5/7/2002]
Old May 7, 2002 | 09:11 PM
VetteNoob's Avatar
VetteNoob
You can use door edge guards for the finishing touch. Most door edge guards used at the dealers are attached using double sided tape. Or if you would rather be safe with the cut edges, you can use 1/4 tubing, split it down the middle and cut to fit. Just some cheap ways to finish it off. Plus you can paint those pieces to match and no one will know the better.
Old May 7, 2002 | 09:45 PM
Jim-K's Avatar
Jim-K
I started with a dremel, and learned quickly that that was going to be rediculus. Pulled out the jigsaw, and had it done in less then a minute.
Jim-K
Old May 7, 2002 | 11:17 PM
Kevin McGrade
Default Re: Did a open lid mod tonight (Jim-K)
Here are some pictures. Sorry about the quality a new camera is on the list :yesnod:
Old May 7, 2002 | 11:20 PM
mikeg826's Avatar
mikeg826
St. Jude Donor '06
looks good :yesnod:
Old May 7, 2002 | 11:23 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: Did a open lid mod tonight (mikeg826)
Very :cool: !!!
Old May 7, 2002 | 11:25 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
FYI: Dremel makes a heavy duty cut off wheel. They're about 3 times thicker than the "standard" cutoff wheel.
Looks good. Here's the cut one from MAD. You did a great job.
Old May 7, 2002 | 11:56 PM
Vette9d1's Avatar
Vette9d1
Default Re: Did a open lid mod tonight (Blue 92)
Kevin- with the new spray paint that looks great! Makes me realize how dull the original paint on my lid has become!
Old May 8, 2002 | 12:17 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
I'm going to do the same thing this weekend Kevin!! :cheers:
I'm assuming thats a plastic cover? Or is it metal?
When you get it on your car, let us know if you can tell a differnce in power :)
[Modified by Mervz, 11:19 PM 5/7/2002]
Old May 8, 2002 | 12:23 AM
Corvette_Z51's Avatar
Corvette_Z51
Default Re: Did a open lid mod tonight (Vette9d1)
Looks good, just need a K&N now to take advantage of all that airflow!
Old May 8, 2002 | 12:40 AM
365ZUM's Avatar
365ZUM
Default Re: Did a open lid mod tonight (Corvette_Z51)
Go with the Holley Power-Shot airfilter instead. It's supposed to be a step above the K&N in both quality and performance. I plan on trying one myself. $65 from Jegs.
http://www.jegs.com/cgi-bin/ncommerc...eight=0#bottom
Sorry for the mess. Just click it. :)
Old May 8, 2002 | 02:31 AM
DMONSVETTE's Avatar
DMONSVETTE
Looking Good. :cool: :cheers:
Old May 8, 2002 | 03:12 AM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Great Job :cool:
:cheers:
Old May 8, 2002 | 03:38 AM
RadPolo96's Avatar
RadPolo96
Did mine the same way. Got kind of a cool whistling sound from the engine now. If it was loud enough you would think I was supercharged. :D
Old May 8, 2002 | 07:14 AM
Kevin McGrade
Hmmm that is a K&N filter believe it or not :eek: I need to clean it a bit
To Did a open lid mod tonight
Old May 8, 2002 | 07:16 AM
Kevin McGrade
Default Re: Did a open lid mod tonight (Mervz)
Its metal mervz, get a hold of a dremel but get some cutoff discs that are heave duty. The metal is about .062 thick.
Use a high goss appliance enamel to finish. I still needto add a couple more coats of paint tonight and get some u channel trimming to finish it up.
As for the power gain i doubt it is anything but it sounds pretty cool
[Modified by Kevin McGrade, 6:18 AM 5/8/2002]
Old May 8, 2002 | 09:25 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Good job bro!! :cheers: :cool:
Old May 8, 2002 | 09:46 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Good tip. Maybe if I use those I won't have to worry about how the disc fragments fly out at high speed when they break anymore.
