TPIS Long Tube Runners
I have purchased an used set of runners for my 86 coupe. TPIS has discontinued the runners. I have read that the stock bolts do not work on the TPIS runners. Does anyone who installed these runners know what size I will need??? Also are all the bolts the wrong size??
thanks for the help...
If they are like the SLP runners then 3 of the bottom bolts are longer than stock.
( like 3" long)
All you need to do is measure the boss length and add 1/2"
same UNC thread as other bolts ( 6 bolts needed )
Socket head bolts preferred for ease of access
( like 3" long)
They are from TPIS.com. Here is the link....http://tpis.com/parts/view/30. I am assuming that SLP's are a different brand.
thanks.
thanks.
Max G’s
St. Jude Donor '10-'11
TPIS sells the big mouth base and runners. You bought those runners from me. Glad they arrived. TPIS does NOT make those runners and they do NOT make the base. I tried to purchase the base awhile back. Eddlebrock makes the base. They "discontinued" it because Eddlebrock couldn't keep up with the demand for themselves and TPIS so they put TPIS on the back burner. Yes, AZ DOES make those runners for TPIS. I talked to them about it. They are discontinued because once again, AZ put them on the back burner. It cost them more and the customer time to wait until they catch up so they discontinued it. TPIS has GREAT American made parts. Everything they sell is made in america and most is made in house by them.
I just wanted to let you know why they were discontinued. They will really wake your vette up. I rode in a 87 before and after with just TPIS runners and it was night and day. The runners I sold you are slightly ported and the plenum was hogged out. Both done by cusinartvette who you did talk to. Best of luck on the install. it was a bear and takes time. Please do not rush. you want to make sure everything is tight and fits well. In the end, it is worth it.
P.S. you might get bruised knuckles. I did. But I also have big hands.
Tpis
thanks again..matt
