Restore engine lubricant, any comments?
Old May 8, 2002 | 01:46 PM
mt_789's Avatar
mt_789
Default Restore engine lubricant, any comments?
Just wondering if anyone has any info. on this or a similar type of product. They claim it coats the cylinder walls and restores compression for high mileage engines. I have 130,000+ on my 88, and was wondering if it would be worth it to try some with my next oil change. The car has always run Mobil 1 (at least that is what the prev. owner told me). I cant complain about performance, maybe a little rough at idle, but no smoke, never stalls and plenty of get up and go... Can this stuff do any damage? If I start using it, will I have to keep using it forever?
Old May 8, 2002 | 08:56 PM
FIBERGLASMD's Avatar
FIBERGLASMD
Default Re: Restore engine lubricant, any comments? (mt_789)
I used it in a 1985 Honda 125 4-wheeler. I believe it made a difference. It smokes less and goes faster. The compression is more just by pulling the rope starter it takes more effort. I put it in my 95 chevy pickup and the oil pressure reads over 40 lbs. at highway speeds.
Old May 8, 2002 | 10:22 PM
jfb's Avatar
jfb
It sounds like you are convinced. Do all of us a favor. Measure and record each cylinder compression before you install the wonder glop. Then after you have run the magic goo for a week, run a compression test and post the results.
Old May 8, 2002 | 10:45 PM
Lone Ranger's Avatar
Lone Ranger
Sorry, I call Snake Oil on it.
Old May 8, 2002 | 10:53 PM
LT5's Avatar
LT5
Default Re: Restore engine lubricant, any comments? (Lone Ranger)
It can't be all that bad if it raises compression right before you trade the car in.
Old May 9, 2002 | 12:40 AM
GRX's Avatar
GRX
Default Re: Restore engine lubricant, any comments? (LT5FIRE)
:yesnod: Also, the effect is diminished after about a week....
Old May 9, 2002 | 10:04 AM
Goody's Avatar
Goody
I think that stuff was put out there as a bandaid for people who can't afford proper car repairs. No better then all those Slick products.....IMO.
Old May 9, 2002 | 10:06 AM
vetluvr's Avatar
vetluvr
St. Jude Donor '08
Another Super Slick Whale Sperm Oil Enhancer Enigine Rebuild In A Bottle.
Don't do it! Stick with the Mobil 1, and NO additives.
Old May 9, 2002 | 10:20 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Restore engine lubricant, any comments? (vetluvr)
:lol: :lol: :lol:
I wouldn't add anything to it. If it truly has run Mobil 1 it's not gonna be as bad as you would think.
Old May 9, 2002 | 11:33 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If the oil has been changed on a regular basis and its not smoking - DO NOT USE THIS CRAP, or any of the other snake oils! Continue to change the oil and filter at regular intervals and you will get many many many more miles out of that engine before it needs a rebuild.
I used it once to try and get a car through "visible smoke" inspection. It didn't work, so we had to rebuild the engine to get it to pass.
To Restore engine lubricant, any comments?
