brakes
Old Dec 7, 2011 | 09:56 PM
az-Thom's Avatar
az-Thom
Default brakes
84 corvette, 10100 miles. off and on the brakes are hard when I start the car. After a min or so they are normal. What's wrong? Oh by the way , the rear reservoir needs to be filled often although I haven't found any leaks. Your thoughts
Old Dec 8, 2011 | 12:20 AM
Churchkey's Avatar
Churchkey
The brake fluid is probably leaking from the rear seal in the master & ending up in the brake booster.
Check the vacuum hose to the booster it may be deteriorated on the inside & not supplying enough vacuum to the booster.
Old Dec 8, 2011 | 12:51 AM
az-Thom's Avatar
az-Thom
Default brakes
thanks Churchkey.
If the master cylinder has leaked into the booster do I need to replace the booster? I'll check for that vacuum leak tomorrow.
Old Dec 8, 2011 | 08:54 AM
Churchkey's Avatar
Churchkey
Originally Posted by az-Thom
thanks Churchkey.
In most cases booster & PCV hoses deteriorate from the inside.
If the hose is bad replace it & see if the booster will work ok.
If the hose is ok its time for a booster & master.
Old Dec 8, 2011 | 02:04 PM
az-Thom's Avatar
az-Thom
Default brakes
thanks for the advice. i'll check those out.
To brakes
