Best tuning computer with parallel and serial?
Old Dec 11, 2011 | 09:51 AM
93VettePilot's Avatar
93VettePilot
Default Best tuning computer with parallel and serial?
My accel gen 7 tuning computer is on its last leg. Would like to know what some of you are using. How are you getting around the parallel and serial port limitation and still getting good speed/compatabilility?
Old Dec 11, 2011 | 07:16 PM
rssshen vette's Avatar
rssshen vette
I used a Dell D610 laptop. It was refurbished and updated with the latest programs. I brought for $200 at a local Computer repair shop. It works great for tuning. I haven't had any trouble with it. It has the serial port connection as well as USB ports.
Old Dec 14, 2011 | 08:50 AM
LT401Vette's Avatar
LT401Vette
USB to Serial Cables will work fine, if you get the right ones.
Try to get these characteristics:
- FTDI Chipset based cables. Prolific is usually OK too, but there older drivers had a nasty bug that could crash Window. That seems to be fixed in the current windows drivers.
- Well shielded and length of 3' or less cable. USB cables are much more sensitive the EM noise inside a car as they run at a lower voltage, so you want it to well shielded and if you need more length, you are better off extending it with a traditional Serial cable.
To Best tuning computer with parallel and serial?
