Got a new cam
Old Dec 11, 2011 | 09:01 PM
onDjuice's Avatar
onDjuice
Default Got a new cam
Well i just got my new cam. Its only a hot cam, but now i need to get fresh valve spring for it. Lots use the lt4 springs are they good or are there better ones out there. I have 1.6 rocker to add to it. Need some help in which springs to get???
Old Dec 11, 2011 | 09:25 PM
rodj's Avatar
rodj
Originally Posted by onDjuice
a hot cam
Not for $40
Given they are the ones the factory used with 1.6 rockers
Old Dec 11, 2011 | 09:34 PM
96GS#007's Avatar
96GS#007
Originally Posted by rodj
Not for $40
Unless you plan to run the engine into the ground, the LT4 springs are perfectly fine.
Old Dec 11, 2011 | 09:51 PM
1963SS's Avatar
1963SS
They only have a little over a hundred pounds on the seat and that's not a lot. The LT4 had lighter valves and that helped them. I would think that they're marginal for a solid stem valve and not acceptable if you ever over rev the engine. Not much room for error, I would think.
Keep the revs below 6000 and they might hold up but there are better choices out there. IMHO
Old Dec 12, 2011 | 03:37 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What would you use then?
(just a question cause I think it was one of my problems with the 383 that ate a lifter)
Old Dec 12, 2011 | 04:55 PM
1963SS's Avatar
1963SS
I'm a fan of the Patriot Gold 8501B spring kit. The price is hard to beat. They have about 150# seat pressure and about 400# open. They come with Titanium retainers that will allow extra RPM's without float, Super 7 locks, spring bases and Viton seals. The whole kit can be bought for less than $300.00 and sometimes around $250.00.
They can control the Comp XFI lobes so they should be able to control just about anything. Lloyd Elliot uses them and so does AFR. AFR actually bought some Patriot's to use on their heads as the stock spring and they buy the same spring from the Manufacturer for use on their heads. That's good enough for me.
Old Dec 12, 2011 | 09:53 PM
onDjuice's Avatar
onDjuice
Are the lt4 spring a direct bolt on. Or is there machine work. I will be spraying with 100 shot later. I,d like to stay away from floating the valves to early in the rpm range. Those Patroit spring look good and at a good price too.
Old Dec 12, 2011 | 10:01 PM
rodj's Avatar
rodj
Are the lt4 spring a direct bolt on..
Old Dec 12, 2011 | 10:14 PM
onDjuice's Avatar
onDjuice
Thank you sir..
Old Dec 12, 2011 | 10:38 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Is this the kit? http://www.summitracing.com/parts/PAR-8501/
Says LS in the description - guess its time for google
Found em on the patriot performance website - $285 plus shipping Looks like that will be an after Christmas buy
Old Dec 13, 2011 | 06:36 AM
onDjuice's Avatar
onDjuice
Are those Patriot spring kit a direct bolton too.
Old Dec 13, 2011 | 08:33 AM
1963SS's Avatar
1963SS
Nope, the kit you want is 8501-B and yes they're a direct bolt in. Here's what Tony Mamo at AFR had to say about the Patriot Gold springs. If they're good enough for AFR they're good enough for me.
That being said, Patriot Performance is not in the "valve spring business"....they purchase them from a manufacturer that supplies many springs to many different companies. I like to refer to them as "Patriot Springs" only because you guys can relate to the very good level of reliability these springs have provided out in the field. AFR's "standard spring" is the EXACT same spring purchased from the exact same supplier as the "Patriot Gold", however, we opted not to pay extra for the gold finish which is purely cosmetic. Some of our earlier 205's that shipped had the "gold" spring because we were in a time crunch and had to purchase them direct from Patriot at the time.
This spring has proven VERY dependable and AFR choose to use this spring based on the benefits of a dual spring design, it met our criteria for seat and open pressures, and the reliablity we saw out in the field has been phenominal....and a good portion of that input came from message boards such as this. We have hundreds of 205's out in the field currently, and so far we haven't heard of a single failure with that spring to the best of my knowledge (at least on an AFR headed engine).
Old Dec 13, 2011 | 09:55 AM
rickneworleansla's Avatar
rickneworleansla
I'm a fan of the Patriot spring kit. The price is hard to beat. The whole kit can be bought for less than $300.00 and sometimes around $250.00.
Same springs I use but I went with the extreme kit for the cam I chose.
https://www.patriot-performance.com/...ction=0&page=2
Old Dec 13, 2011 | 10:52 AM
1963SS's Avatar
1963SS
Yep Rick, that's the one's that I use also. I just forgot about there being two. Thanks for the heads up.
Old Dec 13, 2011 | 07:45 PM
onDjuice's Avatar
onDjuice
So the 8501-B spring are good for a hot cam. I,m ordering my tonight.
Old Dec 14, 2011 | 11:09 AM
rickneworleansla
The Extreme may be overkill for a hotcam. I'll let someone else answer that one. The gold have less spring pressure. Here are the specs compared.
8401-BSBC Gold specs...
Install Height: 1.800"
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.150"
Coil Bind: 1.090"
Retainer Material: Titanium
8501-BSBC Extreme specs...
Max. Valve Spring Lift: 0.660"
Spring Pressure Closed: 155 lbs. @ 1.800"
Spring Pressure Open: 410 lbs. @ 1.140"
Coil Bind: 1.090"
Coil Bind: 1.090"
Old Dec 14, 2011 | 04:12 PM
Pete K's Avatar
Pete K
Coil Bind: 1.090"
Coil Bind: 1.090"
Coil Bind: 1.090"
Based on my experiences, higher spring pressures (within reason) generally offer no negatives, and seem to improve power between 4000 and 6500 rpm.
Old Dec 14, 2011 | 08:13 PM
onDjuice's Avatar
onDjuice
Thanks (rickreeves1) the gold ones look like a good match for the cam i got.
To Got a new cam
