Shifter
Old Dec 11, 2011 | 11:19 PM
assain618's Avatar
assain618
Default Shifter
i have a 1993 vette(manuel) and my shifter keeps on rattling/humming
anyone have same problem or know how to fix this? its driving me crazy
Old Dec 12, 2011 | 12:36 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Dec 12, 2011 | 05:06 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Are you sure it's the shifter, and not the transmission.
Old Dec 12, 2011 | 06:38 AM
Rich B.'s Avatar
Rich B.
Could be foreign objects in the shifter cavity...When I took my shifter out to clean & grease it, I found a butane lighter, some loose cigarettes, a penlight, lots of change, paperclips, and generally junk stuff down there...
Old Dec 12, 2011 | 12:00 PM
twin540's Avatar
twin540
Check you're u joints. Bad u joints well make the rattle a humm noise. Does it rattle all the time or certain speeds?
Old Dec 12, 2011 | 12:35 PM
383vett's Avatar
383vett
Turn the radio **** to the right or open up the exhaust. Make sure the shifter bolts are tight.
Old Dec 12, 2011 | 01:24 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Thats what I do these days. I never heard the ZF making the "normal" noise until I found the exhaust system rubbing against metal parts and the new 3.90 gears. A LOT of drone went away and now I hear a bunch of things. Rock & Roll fixed it all.
Old Dec 12, 2011 | 05:39 PM
assain618's Avatar
assain618
thanks so far, umm... it only rattles when it gets over 40ish mph and if i hold it down it wont humm/rattle. it might be objects in it, im not sure i got it in late october. (my 1st corvette and just put a new clutch in it)
Old Dec 13, 2011 | 12:22 AM
TorchTarga94's Avatar
TorchTarga94
When sitting in the driver seat, look at the reverse lockout ring on the shifter, you will see a tiny nylon allen set screw in the lockout ring. Make sure it is snug, but do not over tighten.
To Shifter
