H4 Headlight Conversion for a C4, part #?
Old May 8, 2002 | 10:41 PM
TIMSPEED's Avatar
TIMSPEED
Default H4 Headlight Conversion for a C4, part #?
Scorp maybe? I seen someone got this upgrade from Summit. All I need is the glass housings. I have the bulbs already. THanks!
Old May 9, 2002 | 12:54 AM
JonM's Avatar
JonM
Default Re: H4 Headlight Conversion for a C4, part #? (TIMSPEED)
Hella 72207 replaces a H6054
Old May 9, 2002 | 02:10 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: H4 Headlight Conversion for a C4, part #? (JonM)
Thanks Jon, got it ordered from Summit for $90 for the both shipped! I have Xenon 90/110 bulbs
Old May 9, 2002 | 05:06 AM
NoWorries's Avatar
NoWorries
Eeek, $90? I spent $80 and it came with bulbs, and I feel that I got ripped.
The headlights in the Corvette(despite being plastic) are the same one that everything uses. My Blazer uses the same set, my roomates Nissan uses the same set, Cheyenne trucks use the same set.
Old May 9, 2002 | 08:18 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: H4 Headlight Conversion for a C4, part #? (NoWorries)
I just went to a parts store and bought two H4 bulb compatible unsealed headlights and the bulbs to go with them (in my case 90-120w if I recall correctly). Total investment was something like $120AUS (hald that to get the figure in US dollars :eek:).
Yes, I pointed the lenses down a little more so as to not blind oncoming drivers at low beam.
Old May 9, 2002 | 08:33 AM
Kevin McGrade's Avatar
Kevin McGrade
Default Re: H4 Headlight Conversion for a C4, part #? (Red 90 L98 Coupe)
I was going to update mine but I couldn't get over it costing over $100 to do it.
I went with the Sylvania Cool Blue
And for $12 a piece you can't wrong. I am very pleased with them :chevy
Old May 9, 2002 | 09:52 AM
98nassau's Avatar
98nassau
Default Re: H4 Headlight Conversion for a C4, part #? (Kevin McGrade)
http://cgi.ebay.com/ebaymotors/ws/eb...151149&r=0&t=0
$48 on ebay!!!!!
Old May 9, 2002 | 03:39 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: H4 Headlight Conversion for a C4, part #? (black96coupe)
I actually have the Cool Blue's in there right now, they are O K, I am expecting to go "WOAH!" when I turn the lights on.
Old May 9, 2002 | 03:51 PM
scorp508's Avatar
scorp508
The headlights in the Corvette(despite being plastic) .....
Early C4s got glass. I don't think they went to plastic until 93 or 94.
Alchemist's Avatar
Alchemist
NC Events Coordinator
For THAT kinna money...i would HOPE so
I have Cool Blue's too...but chose a different route. I bought the bulbs at Walmart for $8.95 each...and found the housings in a salvage yard...$5 for both.
The Cool Blues are "ok"...they're far from $100 worth of "woah" though...
Old May 9, 2002 | 03:57 PM
Kevin McGrade
Default Re: (scorp508)
Plastic on a 92 :yesnod:
Old May 9, 2002 | 05:15 PM
lampedusa's Avatar
lampedusa
Default Re: (Kevin McGrade)
Does this replace the pop-ups? Do they go where the fog lights now go?
Old May 9, 2002 | 05:29 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: (lampedusa)
It's basically a new sealed-beam 6054 unit, that replaces the factory one. Except it's a glass housing with a removeable H4 bulb. (H4's are much brighter than 6054's) I have Xenon 885's in my fog light's, and Xenon 1156's(or are they 1157?) in my parking lights. I'm not particularly happy with the parking light bulbs..the actual 1156(7) normal ones seem to make a brighter light, the xenon's just make a purdy blue light. :D A neat way to make the parking lights REALLY bright, is to turn on the emergency flashers and hold the brakes, (it makes both filaments burn in the parking bulbs)
Old May 9, 2002 | 05:35 PM
lampedusa's Avatar
lampedusa
How did Scorp get his lights to come through the lower light areas, by his license plate? That looks very cool. All the nights shots his his car have the headlights through there, not through the pop-ups... thx
Old May 9, 2002 | 05:44 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: H4 Headlight Conversion for a C4, part #? (lampedusa)
Those must be his fogs and parking lights. That's where they're at. The 885 fog bulbs are rated at 50watts, which is higher than the factory 6054 low beam wattage (35)
Old May 9, 2002 | 05:54 PM
lampedusa's Avatar
lampedusa
He just doesnt use his pop-ups then?
Old May 9, 2002 | 06:01 PM
TIMSPEED's Avatar
TIMSPEED
Uhh...Scorp, care to chime in any time now?
To H4 Headlight Conversion for a C4, part #?
Old May 9, 2002 | 06:02 PM
scorp508's Avatar
scorp508
Those are my foglights. 50W normal 885 bulbs.
You mean like this?
My headlights are off, my foglights/parking lights are on.
[edit]
p.s.
You'd know if it if my headlights were on. Bright suckers. :D
[Modified by scorp508, 5:03 PM 5/9/2002]
Old May 9, 2002 | 06:14 PM
TIMSPEED's Avatar
TIMSPEED
Ahh yes, the drag strip pic. Yeah, I run just fogs and parkings are the strip, or even when I race anywhere. ;) It just gives the car a more cleaner look (maybe more aerodynamic too, who knows)
Old May 9, 2002 | 08:31 PM
guywade's Avatar
guywade
so can you run both at the same time?, are they on separate circuits? did you have to do anything with the fuses as in from 10amps to 15amps? i thought i read a c4 article, on lamp upgrade to brighter bulbs , required a larger fuse!
thanks Guy :confused:
