New crate motor
Old Dec 19, 2011 | 12:48 PM
Jhark's Avatar
Jhark
7th Gear
Default New crate motor
I put a new GM 350 crate motor #12520270 4-bolt main 8.75:1 compression ratio (rated as 190 hp with stock heads and cam) in my 1991 Coupe. My GM tech removed my cam and alm heads from my L98 motor (all in very good shape). I am breaking in the motor now with 700 miles so far. Any ideas on what this motor will produce HP wise with the corvette FI, cam and heads from the L98? Any other ideas or tips? Car runs great, will change the oil and have tech go over it at 1000 miles.
Appreciate your thoughts.
Jim
Old Dec 19, 2011 | 02:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
This one?
http://www.summitracing.com/parts/NAL-12520270/
Old Dec 19, 2011 | 02:07 PM
1991Z07's Avatar
1991Z07
The stock 1991 L98 made 250 hp...
Not sure what the cam profile is in that block...but the iron heads will give you additional weight not needed in the Corvette.
Old Dec 19, 2011 | 02:14 PM
Jhark's Avatar
Jhark
7th Gear
I pulled the cast iron heads off, and the cam out of the crate motor, and put my still good L98 fuel, injection, cam from the L98 and the heads from the L98 onto this new crate motor.
Jim
Old Dec 19, 2011 | 02:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
Probably make very close to the same power it had when new then. If there was a difference you probably wouldnt know.
Old Dec 19, 2011 | 02:25 PM
Jhark's Avatar
Jhark
7th Gear
That's what I was thinking. Thanks
Old Dec 19, 2011 | 03:55 PM
383vett's Avatar
383vett
Your original L98 had 10:1 compression, the crate 8.75 as you stated. I'm not sure if the difference was in the heads or in the pistons. If your current pistons are dished, you will be down on compression and down on horses. Over one point of compression is a lot.
Old Dec 19, 2011 | 04:01 PM
Pete K's Avatar
Pete K
Going from a 76cc combustion chamber down to a 58cc chamber will take that crappy compression ratio up to near 10.5 to 1.
Should run a pinch better than stock.
Old Dec 19, 2011 | 06:43 PM
leesvet's Avatar
leesvet
I don;t think the stock motor was ever 10:1....9.5:1 is all I ever read about.
After mine was bored and used thin gaskets all I ended up with was 10.5:1 with stock style pistons, same cut outs same dish.
I agree that the change from iron to alum heads alone will hopefully get his compression up...at <9:1 he could run brandy in the thing and not knock...E85....low compression motors are for junk fuels..
Old Dec 19, 2011 | 09:55 PM
383vett's Avatar
383vett
I believe that in 91 the compression was bumped to 10:1 although the hp rating did not change. Don't ask me how or why.
Old Dec 20, 2011 | 10:00 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
This is from memory but I believe the 1991 pistons were flat tops and compression was @ 10.2:1 They may have tinkered with the cam profile or just stated a low HP rating to make the LT1 look better in 1992. Either way the 113 heads didn't change.
Old Dec 20, 2011 | 05:00 PM
BADDUCK's Avatar
BADDUCK
FWIW 90, 91 cam had slightly less lift than the 88, 89 cam.
To New crate motor
