tire pressure
Old Dec 26, 2011 | 05:06 PM
dasher's Avatar
dasher
Default tire pressure
Hi all,
Can't seem to find the tire pressure recommendations no where on the Vett or the manual. Know its 35psi for over 150mph but not for everyday driving.
Dasher
Old Dec 26, 2011 | 05:37 PM
Red Dwarf's Avatar
Red Dwarf
32 Lbs. is a good average.
Old Dec 26, 2011 | 05:38 PM
ProjectC4's Avatar
ProjectC4
Default Tire pressure
I have a 1984 with the Z51 performance suspension. The recommended pressure is 35 PS I. However I have read that the Z51 had such a hard ride that Chevy issued a bulletin that 24 PSI was OK if the possibly increased or uneven tire wear was acceptable to the owner. I have also come across the opinion that the 35 PSI figure had a lot to do with the cars fuel mileage. I usually run 30 PSI which works fine for me. My tires are new but the car needs rear bushings, etc so its handling is not that great so I could probably run any tire pressure and not notice much difference. I have run 24 which felt fine, too but I was worried about wear.
Old Dec 26, 2011 | 06:01 PM
popo8's Avatar
popo8
Wow, I run mine HARD... 50psi
Old Dec 26, 2011 | 06:05 PM
STL94LT1's Avatar
STL94LT1
There should be a sticker on your driver's door. It calls for 30
psi/cold on my 94.
Old Dec 26, 2011 | 06:15 PM
dasher's Avatar
dasher
Thanks to all, I don't have anything on my door post except the 35 psi.
Thanks again
dasher
Old Dec 26, 2011 | 06:32 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Why so high?
Old Dec 26, 2011 | 06:43 PM
93Rubie's Avatar
93Rubie
I run 40psi when I auto-x and the tires never roll onto the sidewalls just up to them. Why 50psi, has to ride like a brick.
Old Dec 26, 2011 | 06:50 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
32 psi
Old Dec 26, 2011 | 07:07 PM
nutz4c4's Avatar
nutz4c4
Originally Posted by PLRX
32 psi
Old Dec 26, 2011 | 07:36 PM
c4cruiser's Avatar
c4cruiser
Starting with the '94 model year, stock tire pressures were lowered from 35psi to 30psi to improve ride quality.
If there is no sticker on the driver's door, somebody removed it. That sticker would also show the specific tire size for the car, based on suspension options, and the maximum cargo weight that can be carried (including the driver).
You can adjust the tire pressure for what you feel is the best for handling or ride comfort. I would not go above 35psi for street use. Tire pressure for autocross and track days can be different based on the tire itself, the air temps, alignment, and pavement temps.
As the tire heats up, the tire pressure will increase.
Old Dec 26, 2011 | 07:38 PM
popo8's Avatar
popo8
Originally Posted by RollaMo-LT4
Why so high?
No real reason... I just kept driving and adding, until I liked how it drove...
To tire pressure
