clutch fluid ??
Old May 9, 2002 | 10:41 PM
YellowC4's Avatar
YellowC4
Default clutch fluid ??
I changed it and it turns from clear to dark grey in two days is that Normal
I change the master and the slave not to long ago :flag
Old May 9, 2002 | 11:13 PM
tempest's Avatar
tempest
Default Re: clutch fluid ?? (YellowC4)
grey is water or air in the fluid. (can't remember which.)
in either case it might be a leak in the system.
Old May 9, 2002 | 11:48 PM
bogus's Avatar
bogus
clutch fluid is essentially brake fluid.
hence, it is hydroscopic. it attracts moisture. and it makes a mess of things... a huge mess...
I suggest getting a pheonix injector... it is a tool designed to bleed clutch systems. it pushes fluid up from the bottom.
I would simply pump new fluid up... and replace it that way.
To clutch fluid ??
