1985 shaking on acceleration
Old Dec 28, 2011 | 04:10 PM
bjones955's Avatar
bjones955
3rd Gear
Default 1985 shaking on acceleration
I have a 1985 manual 4-speed corvette and recently when i accelerate the car begins shaking. Thinking it had something to do with the u-joints i replaced them yet the shaking is still continuing. Hoping someone has had this problem or knows what it might be
Old Dec 28, 2011 | 04:22 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Drive shaft U-joints; tire balance; wheel damage; hub bearings ???? All are possibilities.
Old Dec 28, 2011 | 06:36 PM
bjones955's Avatar
bjones955
3rd Gear
Did the Drive Shaft u joints and the tire balance and wheels are good. The Shaking only occurs when i take off and accelerate, after i reach about 5 mph the shaking begins to go away and is completely gone by 10
Old Dec 28, 2011 | 08:34 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
How is your clutch and the clutch fluid reservoir?
Old Dec 28, 2011 | 08:36 PM
bjones955's Avatar
bjones955
3rd Gear
When i purchased it the clutch needed to be replaced so i had a new clutch put in about 4 months ago and the fluid is good it is not low
Old Dec 28, 2011 | 09:30 PM
383vett's Avatar
383vett
If it starts right when you take off and goes away at 5-10 mph, you probably are experiencing clutch chatter. A new clutch could have this if not installed correctly or the flywheel not resurfaced.
Old Dec 30, 2011 | 09:23 AM
FOURSPEEDVETTE
To 1985 shaking on acceleration
