Fuel pressure regulator diaphragm
it seems to be seeping from the edge of the regulator between the diaphragms...there are 2 sandwiched under the regulator cap. Its leaking under the cap between the rubber diaphragms? Not into the cap but thru the stem in the rubber.
Has anyone seen this before?
I kinda thought that if it were leaking past the diphragm middle that it would fill the cap and vent out thru the vac port...but its not..it seems to be seeping out around the edges. After pulling the cap off I saw the upper diaphram was rotted (bacon neck) in the center around the plunger that goes thru to the bottom seat surface. There is/was no tear between the 2 rubber layers.
The area that contacted the cap or the regulator bottom was not damaged or rotted. No tears between screw holes.
I'm assuming the leak was getting past that rotted rubber that was separating from the fabric...but wanted to hear if anyone else had a similar failure of the rubber diaphragm?
Its safe to assume that its just another casualty of methanol/ethanol poisoning..
Picking up new one in the morning then reassembling.
Anybody ever seen one leak between the rubber sheets? leak out the edge not thru the vac port..? anyone?? hello? McFly???
Old adjustable same diaphragm adj cap. beein in place for 10+ yrs.
I am asking about THE LEAK ITSELF....WHERE HOW. The question IS:
has anyone seen a leak thru the regulator described in the above post?
TJM
What keeps the damn thing from leaking. NEW diaphram and NEW regulator hat.......
