Which? SR or MR...help!
May 10, 2002 | 09:53 AM
I am considering either a superram or miniram. Which should I get? I have the richmond 6spd close ratio, soon to be installed AFR190 heads, soon to be upgraded roller cam (must have a good idle). ported shorty headers into dual 2.75 pipes, into PE muffs. :confused:
With the 6-speed 90% of the people will tell you to get the Miniram. The question is are you willing to spin your motor to 7 grand? :)
May 10, 2002 | 09:55 AM
Re: (scorp508)
I was opting for 5500-5800rpm.
[Modified by GRX, 5:56 AM 5/10/2002]
May 10, 2002 | 11:43 AM
Then go SuperRam. With the combo all together you should be shifting around or at 6000 with the SR. It makes it's peak power right around 5400-5700.
May 10, 2002 | 12:22 PM
Re: (scorp508)
I would go SR if you want to shift below 6k rpm. But id take a long look at having the bottom end built to take the 7k abuse and then get a MR.
May 10, 2002 | 12:39 PM
Re: (vader86)
since you live in CA. (the smog police capitol) and if you want to pass the sniffer tests. Then you'll pretty much have to go SR.
The MR dosn't have a EGR, so it would be tuff to pass emissions.
May 10, 2002 | 04:07 PM
Re: (ol,RJ)
I'm wondering why TPiS never included provisions for an EGR hook-up in the MR? I mean, wouldn't it open up more of a market for them? :confused:
May 10, 2002 | 04:11 PM
St. Jude Donor '05-'06
Re: (GRX)
If you need to smog it go with the Superram. :cuss
Just one of thoses California things :crazy:
May 10, 2002 | 04:14 PM
Re: (GRX)
Call them up and ask!
I am willing to bet it is the amount of $$$ it would cost them to get the CARB # vs the amount of sales they would have in CA.
It's the same type of thing with trying to find a set of headers legal for the L-98 in CA.
