Distributor(s)
Old Dec 31, 2011 | 01:19 PM
Iown1badvette's Avatar
Iown1badvette
Default Distributor(s)
Whats a good distributor to run for a L98?
Just trying to get opinions
Old Dec 31, 2011 | 01:24 PM
oldalaskaman's Avatar
oldalaskaman
dui
Old Dec 31, 2011 | 01:31 PM
Iown1badvette
Are the stock factory distributors ACDELCO?
Old Dec 31, 2011 | 01:45 PM
oldalaskaman
yes
Old Dec 31, 2011 | 02:22 PM
WW7's Avatar
WW7
The stock distributor is a "Delco Remy"...And just for your information, you might as well keep using the stock unit because I just bought a new "Douglas Unified Ignition" (DUI) High Performance racing distributor and guess what brand name is stamped on the casing....Delco Remy.....They just put there own coil and ICM into it, charge $319.00, and its a High Performance unit.....Yea, Right.....WW
Old Dec 31, 2011 | 02:40 PM
oldalaskaman
aftermarket rarely re-invents the wheel
Old Dec 31, 2011 | 03:14 PM
nutz4c4's Avatar
nutz4c4
...Better to get the DUI cap and module and add it to your Delco unit. I got lucky and scored an almost new DUI unit for $30
Old Dec 31, 2011 | 03:23 PM
WW7's Avatar
WW7
Originally Posted by nutz4c4
... I got lucky and scored an almost new DUI unit for $30
$30.00....I now hate you Mike........WW
Old Dec 31, 2011 | 03:27 PM
nutz4c4's Avatar
nutz4c4
I got big shoulders Wayne......By the way you're probably third in line on the hatin'..
Old Dec 31, 2011 | 06:50 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
What's wrong with the original?
Old Dec 31, 2011 | 07:47 PM
oldalaskaman
chevys hei is the best thing that ever happened to an engine, for a stock setup , its perfect. for mildly altered , with a few upgrades, its still the best, thats why DUI and others put them in everything from toyota's to fords, they are reliable to a fault. I installed one of DUI's setups in my ford tow truck when I got tired of fords ign. module. you can even take a chevy ign module , fasten it to a fender with a zip tie and with grease under it , run wires to it, and run any vehicle that has a ign module style setup and a bunch that dont. it eliminates needing a resistor , either ballast or wire. I did that on my tow truck also. hope this helps
To Distributor(s)
