Air leak test question
Old Jan 4, 2012 | 06:36 AM
S.D.M.F's Avatar
S.D.M.F
Default Air leak test question
I have an air leak from what I can tell by ear coming from the throttle body on my way '89. I had the fuel system cleaned out couple of months ago, part of that was them swabbing out the throttle body. It ran great for awhile but that's about when I noticed the whistling noise, sometimes the noise goes away for a few minutes. Any ideas? Thanks for your time.
Old Jan 4, 2012 | 12:09 PM
95tripleblack's Avatar
95tripleblack
A spray of carb cleaner or throttle body cleaner (during idle) near the whistling sound will verify the air leak. If the idle changes there is a leak. If I had to guess I would say the intake boot is not installed properly and rolled under at the bottom, just a guess.
Old Jan 4, 2012 | 12:16 PM
sailorsteve's Avatar
sailorsteve
With the engine running, look for cracked or disconnected vacuum hoses. You can feel all around on them where you can't see, and if you touch a leak, you will hear the sound change. Did the noise start just after the work, or did it develop some time later?
Old Jan 4, 2012 | 12:23 PM
S.D.M.F's Avatar
S.D.M.F
It started shortly after the work. At low r.p.ms its just barely noticeable.
Old Jan 4, 2012 | 12:27 PM
sailorsteve
Do you know what, if any, disassembly the shop did?
Old Jan 4, 2012 | 12:31 PM
S.D.M.F's Avatar
S.D.M.F
Yea I watched them do the work. The only disassembly was them taking the intake boot off.
Old Jan 4, 2012 | 12:39 PM
sailorsteve
If the intake boot is not on correctly, as stated, it could cause the whistle. But also, if here was a vacuum hose ready to crack, or ready to fall off, just a touch could have affected it. Suggest you do the check I mentioned earlier. Does the car run the same?
Old Jan 4, 2012 | 12:43 PM
S.D.M.F's Avatar
S.D.M.F
It feels like there is a small drop in power and mileage efficiency. It was a gradual drop by the way.
Old Jan 4, 2012 | 03:59 PM
sailorsteve
Is the idle speed normal?
Old Jan 4, 2012 | 05:49 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check the vacuum hose attached to bottom of TB, driver side.
Old Jan 4, 2012 | 06:37 PM
S.D.M.F's Avatar
S.D.M.F
OK so I re-tightened the metal band on the intake boot, that got rid of the whistle. Its still making an unfamiliar noise but not noticeable until it gets past 2k rpm. The idle speed is at 7-800 rpm.
I got the car in October and other than the sound of the cooling fan, its been extremely quite under the hood.
Old Jan 5, 2012 | 03:22 AM
Cliff Harris's Avatar
Cliff Harris
Before I got to the bottom of the thread I was thinking exactly what Agent 86 said. It sounds like the vacuum line that goes to the EGR solenoid (mounted on thermostat housing) is disconnected.
To Air leak test question
