Bladder Doesnt Hold Air!!! How Do I Fix?????
Old May 10, 2002 | 04:46 PM
StealDads67's Avatar
StealDads67
Default Bladder Doesnt Hold Air!!! How Do I Fix?????
Hey Guys,.... My Driver side pump works... but it doesnt fill up the bladder.... Im guessing the bladder is torn and I would need a new one. The pump works fine though. How much would it run me... Is it an easy fix... any input..... Thanks All
Old May 10, 2002 | 08:03 PM
bogus's Avatar
bogus
Default Re: Bladder Doesnt Hold Air!!! How Do I Fix????? (StealDads67)
the bladders are rather cheap... except Ecklers catalog is about useless...
Old May 11, 2002 | 10:49 AM
Craven Morehead's Avatar
Craven Morehead
6th Gear
"Bladder Doesnt Hold Air!!! "
I think you need to have a talk with your girlfriend..... :rolleyes:
Old May 11, 2002 | 11:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Bladder Doesnt Hold Air!!! How Do I Fix????? (Craven Morehead)
"I think you need to have a talk with your girlfriend..... " :lol:
Seriously though, yesterday I finally did the pump repair with the "rubber glove trick" and also found that the bladders didn't hold air.
Looks like time it's to struggle with the seat back.
Old May 11, 2002 | 11:24 AM
StealDads67
Default Re: Bladder Doesnt Hold Air!!! How Do I Fix????? (65Z01)
Whats this so called "Rubber Glove Trick" I have an idea.. but i never heard of it...
Old May 11, 2002 | 11:51 AM
65Z01's Avatar
65Z01
Sorry, that's not another attempt at medical humor. There's a C4 Tech Tip on cutting a circular diaphram from a Playtex rubber glove to replace a ruptured one in the pump.
Upon following those very good instructions I found that the diaphram in my pump wasn't ruptured but rather disintegrated. After the repair the pump now pushes air but the bladders still won't inflate.
Old May 11, 2002 | 08:33 PM
Shark ssn591's Avatar
Shark ssn591
[QUOTE]There's a C4 Tech Tip on cutting a circular diaphram from a Playtex rubber glove to replace a ruptured one in the pump.
Upon following those very good instructions I found that the diaphram in my pump wasn't ruptured but rather disintegrated. [QUOTE]
I did that repair (to both pass. and drivers pumps) now 2 of 3 drivers bladders inflate and 1 of 3 passenger bladders inflate... I'd love some info on those seat bladders... that will be nice when all 3 drivers side work (I'm old now, & boy would that help my "aching back").
[Modified by Shark ssn591, 7:33 PM 5/11/2002]
To Bladder Doesnt Hold Air!!! How Do I Fix?????
