hooker headers with afr heads ?
Old May 10, 2002 | 05:38 PM
daddydahlin's Avatar
daddydahlin
Default hooker headers with afr heads ?
Can this be done I just read that the headers don't bolt to the heads is this true . If so what heads do bolt to the hooker headers
Old May 10, 2002 | 05:52 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: hooker headers with afr heads ? (daddydahlin)
I don't knwo where you read that but the Hooekrs bolt up, IF you have the right heads. The AFR 190 L98 angle heads work fine. There are lots of people here susing them together. I test fitted mine on my 383 with AFR 190's on the engine stand before I put the headers in on my L98.
Old May 10, 2002 | 06:37 PM
scorp508's Avatar
scorp508
Default Re: hooker headers with afr heads ? (Fastguy)
Like Fastguy said, the AFR w/L98 angle plugs are fine. The people who order the straight plugs have problems.
Old May 11, 2002 | 06:36 PM
CFI-EFI's Avatar
CFI-EFI
AFR sells heads with 3 different spark plug angles. Straight, L98 angle, and AFR proprietary angle. The foot note in the Hooker catalog, refers to the AFR proprietary angle.
Old May 11, 2002 | 06:48 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: hooker headers with afr heads ? (CFI-EFI)
Now THAT explains it. There are 2 different angle heads!! thanks!
Old May 13, 2002 | 09:07 AM
JoBy's Avatar
JoBy
Default Re: hooker headers with afr heads ? (FoolCrzy)
These are my new Hooker 2151 and AFR 190 with L98 angle plugs.
Very good access to all spark plugs and the wires are out of the way too.
They were easy to install too. The driver side could go in both from the top and from below. Passenger side went in from below.
It could not be any better!
(click to enlarge)
To hooker headers with afr heads ?
