1985 Rear Export Lighting wiring help needed!!
Old Jan 8, 2012 | 06:33 PM
vetterss's Avatar
vetterss
Default 1985 Rear Export Lighting wiring help needed!!
I have a pair of orange NOS export lights to put into my '85 C4. I've used these in a '86 before but that was many years ago. I can't find the wiring notes I had. Most of the installs say to cut the white wire at the brake switch but I can't remember why.
My question to anyone that may help is; can't the wires at the outboard lights be cut to eliminate the brake and tail light function but keep the turn function? Can this be done without having to tap into a light source somewhere else on the car? The center high mount light was used for some reason on the later cars.
I have the service manual and I know what each of the wires do at the light itself, but can't put the white wire cutting step at the brake switch into the scheme of the install or if I even need to do it on my '85. Help!!
Old Jan 9, 2012 | 07:14 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Doesn't sound like it! The tail lights have two filaments, one for marker or running lights and the other for stop and turn. You can't remove the stop function from that filament without also removing the turn function as both run along the same wire from the multifunction switch to their respective lamps (yellow-left and green-right), unless you clip the white wire. Now none of the rear lights have stop function, only turn. You'll need to run a separate stop signal wire from the brake switch to the inside lights. Then clip the yellow (left) wire and green (right) wire on the inside lights and connected your new wire to the lights yellow and green wires you just clipped. Last, clip the brown wire from the outside lights to remove the marker/running function from these so they will only act as turn lamps.
Old Jan 9, 2012 | 01:53 PM
vetterss's Avatar
vetterss
Default rear export lights
That was a very simple way of providing the missing link to the wiring questions I had. It didn't click about the dual use of the one wire and filaments. Thanks for the guidance, even with the sarcasm..........
Old Jan 9, 2012 | 04:14 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
What can I say, I'm a *****!
Old Jan 9, 2012 | 09:20 PM
oldalaskaman's Avatar
oldalaskaman
lessee, nope, don't see no sarcasm, excellent info though, many thanks, respectfully, bob
To 1985 Rear Export Lighting wiring help needed!!
