95 LT won't start
Old Jan 11, 2012 | 04:17 PM
jimlynn1's Avatar
jimlynn1
Cruising
Default 95 LT won't start
My 95 LT 1 with Vortech supercharger and ignition controller won't start.
Ran fine day before , no fuel pressure and no spark although the auxliuary fuel is working. Main fuses all check good. My optispark is 8 months old. The battery and check engine light stay on after i try to start .Any help is much appreciated .
Jimlynn1
Old Jan 11, 2012 | 11:06 PM
96GS#007's Avatar
96GS#007
Does it crank? If no, try cleaning the pellet on the key. Having said that, you should at least have fuel pressure. Check for voltage at the pump. When you turn the key to "run", you should see voltage for ~2 seconds.
Old Jan 12, 2012 | 10:37 AM
jimlynn1's Avatar
jimlynn1
Cruising
Yes it does crank. I checked all main fues blocks for voltage with ignition on ,
I have a Crane retard controller and it has power and the auxiliary fuel pump is working .
I don't know if the PCM actually controls the two , ignition and fuel pump ? The battery and check engine lights remain on after I try to start ?
Jim
Old Jan 13, 2012 | 01:53 PM
96GS#007's Avatar
96GS#007
Jim
Refer to my prior post...
Report back your findings
To 95 LT won't start
