Brakes
Old Jan 12, 2012 | 09:44 PM
bigfat55's Avatar
bigfat55
Cruising
Default Brakes
Hello, I have a 1955 chevy 210 sedan 454 with a late c4 suspension conversion frame and I'm in the market for a complete 13" front and 12" rear brake system. I need your recommendations, like what to buy and where, pro's and cons if any and not to expensive. I am not racing or taking it to a track, just out for crusing. I've already looked at baer and wilwood but a little to expensive for my wallet. I'm not car saavy, so if you can provide as much detail as possible, that would be great. Oh and one more thing, some bling would be nice. Thanks.
Old Jan 12, 2012 | 10:18 PM
rodj's Avatar
rodj
C5 Vette brakes are a cost effective solution
http://forums.corvetteforum.com/c4-t...done-pics.html
but only fit certain 17" rims
require a custom adapter to mount the caliper
http://www.pnwzr1.com/brake_install.htm
or C6
http://forums.corvetteforum.com/c4-t...-and-pics.html
Old Jan 12, 2012 | 10:46 PM
Deepa's Avatar
Deepa
For crusing, i would buy all four mounting brackets here on the forums, the 2 heavy duty for the front and the normal ones for the rear, then purchase 4 brand new reman calipers from rock auto. After pads and rotors, you would be looking at 800ish for a lot of brand new brake parts
Old Jan 13, 2012 | 01:15 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Jan 13, 2012 | 03:09 PM
bigfat55's Avatar
bigfat55
Cruising
or C6
Rodj, thanks for the links, c5 looks nicer than the c4's
Old Jan 13, 2012 | 03:10 PM
bigfat55's Avatar
bigfat55
Cruising
I will check out rock auto, thanks for the tip deepa
Dave
Old Jan 14, 2012 | 07:05 PM
bigfat55's Avatar
bigfat55
Cruising
Ttt
Old Jan 14, 2012 | 07:18 PM
rodj's Avatar
rodj
Ttt
What more do you want?
Either fit the J55 HD 13" brakes that were optional for your suspension as mentioned above
or the cheaper C5 brakes
or C6 brakes.
You say you don't like the cost of the aftermarket options
Old Jan 14, 2012 | 07:42 PM
bigfat55's Avatar
bigfat55
Cruising
Rodj, I was just wondering if there was something in between the oem and the high end stuff? What do you think the j55 HD will cost me? Thanks
To Brakes
