93 Ruby = new gears
Old May 11, 2002 | 11:11 AM
Ozman's Avatar
Ozman
Default 93 Ruby = new gears
I'm finally going to bite the bullet and change out the 2:59's for 3:73's on my auto Ruby. I've have two quotes on price so far. The cheapest place says around $1000 for parts and $300 for labor. They could get it done in a day or so.
Is this about right on price? I'm sure somebody will say they had it done cheaper,
but I don't want to look high and low for the cheapest price. I just want reasonable. The shop I talked to does lots of performance work and I think they would do a good job.
Old May 11, 2002 | 11:44 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: 93 Ruby = new gears (Ozman)
:cheers:
Old May 12, 2002 | 08:34 AM
93aquaConvert's Avatar
93aquaConvert
Default Re: 93 Ruby = new gears (mackeyred96)
Make sure they recalibrate the speedo and adjust the shift points.. :cheers:
Old May 12, 2002 | 03:30 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Re: 93 Ruby = new gears (93aquaConvert)
Yes, Make sure that the gers in the back of the tranny are done right for your speedometer. Also, you have to put shift point weights (a kit) for you to adjust shift points as our 93's are not electronic tranny's as we have a TV cable. Steve
Old May 12, 2002 | 04:29 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: 93 Ruby = new gears (steve40th)
price sounds about right :yesnod:
Old May 12, 2002 | 06:49 PM
mfranco's Avatar
mfranco
Last month I did the same switch on my 93'. I went with the GP (which is a complete rearend with new posi-unit) from ZIP Products for $759.00 plus my rearend as a core. I think it was advertised as a 3:54 setup but I had them use 3:73 instead. I also purchased the heavy duty rearend cover for an additional $325.00. This was an easy swap and I think the best way to go. You should call and speak with Justin if you have any questions about their set-ups.
You will be very happy with the results. It will seem like a completely different car.
Good Luck :) :)
Old May 12, 2002 | 09:15 PM
red-y's Avatar
red-y
Mine was $900 and included new bearings. The Spedo was done seperately, if your price includes this as well all is cool. You will love this mod.. :yesnod:
Old May 13, 2002 | 02:54 AM
Daniel DK's Avatar
Daniel DK
why do you need to change your shift points??? won't the stock setting work?
To 93 Ruby = new gears
