First 383 Build, need advice please.
Old Jan 15, 2012 | 08:17 PM
tusairon1's Avatar
tusairon1
Id be happy with 12s for now. Gonnq let my son take it from there in a couple years. Dont want to give him too much to start out with. which brand rods would be recommended? Or, should I buy a kit (crank, rods, pistons) instead of mixing things up? Ive been out of this game for about 25yrs. My how things have changed!
Old Jan 15, 2012 | 09:07 PM
96GS#007's Avatar
96GS#007
For 12s, I wouldn't bother with the stroker unless you have to. Cam, intake, AFR heads, headers/exhaust, and 3.73 gears will easily get you into the 12s.
Old Jan 15, 2012 | 10:55 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
What do you mean by too much? 450rwTQ is quite a bit!
FWIW, I'd recommend the Scat 9000 383 crank with Scat's I-beam rods and some nice 4032 forged alloy pistons (I really like SRP Professional series due to price/weight).
With a FIRST that wouldn't be revved above 5500 rpms, there's no need to invest in a forged crank. OTOH, if you've got the money, get a Scat 4340 crank to round out the Scat RA.
With a long-runner intake, I might be more inclined to do the 383 and port the heads vs buying AFRs. I say this after seeing your statement about "not giving him too much".
It's a tough choice since more torque is harder on the trans/rear. (Don't know how wild your kid is either!)
Old Jan 15, 2012 | 11:20 PM
tusairon1's Avatar
tusairon1
I got the block today. I want to give him (my son) a good foundation for later, but not hinder peformance now. I went to order the rotating assem and got stuck 383 or 396. When I was racing they said there's no replacement for displacement, but I found a rotating assembly, forged crank, H beam rods, and forced flat top pistons for about $1700. Planning on the LT4 hot cam, the FIRST intake, and just flowing the stock heads, and get a new chip for now. Does that sound like a mid 12 second car with 308 gears and a 2400 stall?
Thanks you for recommending scat. I heard some bad things about Eagle.
Old Jan 15, 2012 | 11:50 PM
GREGGPENN's Avatar
GREGGPENN
Why spring for H-beams with a 5500rpm motor? 6k tops.
Old Jan 16, 2012 | 09:02 AM
tusairon1's Avatar
tusairon1
Well I don't know what might cross my mind between now and then so if I make the lower end solid now then I know its done.
Old Jan 16, 2012 | 12:08 PM
GREGGPENN's Avatar
GREGGPENN
Gonna let my son take it from there in a couple years. Dont want to give him too much to start out with.
You're giving him too much!
Old Jan 16, 2012 | 12:28 PM
96GS#007's Avatar
96GS#007
How do you know the lower end is solid if you don't know what you're going to do???
Old Jan 16, 2012 | 01:01 PM
tusairon1's Avatar
tusairon1
should be good to a thousand hp if so desired. I call it insuracnce!
Old Jan 16, 2012 | 01:16 PM
tusairon1's Avatar
tusairon1
I just dont like cast cranks and cheap rods when your throwin alot of torque around. Also I thought I might play around with a little N.O.S.... Hope I didnt open a whole nother can of worms with that one but thats what I meant by I dont know what I might do later. I was hoping I could tone it down for him or stick the stock motor back in at first. I havent had or built a fun car since we started having kids (3). Now theres only 1 left at home age 12 and its my turn to play a little! Adam (my 12 year old) repects his toys (dirtbike, 4 wheeler) and the power they have.
Old Jan 17, 2012 | 01:03 PM
tusairon1's Avatar
tusairon1
All I seem to find are mid length 1 3/4in hooker headers. Tuned. Is this what I should run or are full length better? If so, where to look? I was on Summit.
Old Jan 17, 2012 | 01:26 PM
GREGGPENN's Avatar
GREGGPENN
Sounds like you want the best....
http://forums.corvetteforum.com/c4-t...h-headers.html
Old Jan 17, 2012 | 02:08 PM
  #33
cv67's Avatar
cv67
St. Jude Donor '05
Tq doesnt necessarily kill parts, rpm does.
Good to see youre thinking ahead on future upgrades and getting a sound shortblock out of the gate.
Old Mar 5, 2012 | 08:19 PM
  #34
tusairon1's Avatar
tusairon1
OK. Short bock is done. I live in Nebraska and we have no inspection or smog control. What all can I eliminate as far as pump , egr , and if I went with a pro-jection system instead of the FIRST T.P.I. will all the dash componants work ok?
Old Mar 5, 2012 | 10:08 PM
  #35
cv67's Avatar
cv67
St. Jude Donor '05
Got a PN on that system?
Why not the FIRST?
You can get away with 1-5/8 long tube headers too if you like.
Youll make so much torque with the good heads you wont be able to keep yourself in tires.
Some eliminate the EGR im a fan of leaving it on.
Dont need titatnium retainers either.
Youll need a good tune on your ecm too dont forget.
Old Mar 5, 2012 | 10:49 PM
  #36
tusairon1's Avatar
tusairon1
Thats why i was thinking of the Holley projection system . Its tunable inside the car without burning a chip every time you change something. P/N 510-950-21s
Old Mar 6, 2012 | 12:04 AM
  #37
Zix's Avatar
Zix
I see this ending badly for your wallet, and your expectiations
