Would anyone be willing to help me with a good "recipe" for building a strong 383. I have an 87 C4. I've got a 4 bolt 350. Machining will all be done threw a local shop. I plan on buying a FIRST intake and throttle body and port matching my 87 heads to it. Should I increase the valve size? What c.r. should I run? I already put the dana44 in and had the 700r4 rebuilt. I have a 2400 stall right now or should I go higher? Need recommendations for the cam I should use and that would tell me what stall I need. I think. Also need some ideas on the chip to use or who to contact. I only have the money to do this once and get it right. I'm hoping for a low to mid 12 second car. Is this realistic? Thanks for any and all help. You guys are great!
307s and I was going to keep the 87s just get them ported to match the first intake. bigger valves if needed. titanium retainers and new springs. Should I not do this?
talk to tpi421vette on the heads
the stockers will choke that combo big time even with some work done to them
thats will pull super hard youll love it.
A common and proven cam for the 383 is the Lingenfelter LPE 219. But I have to defer to those familiar with the power band of the First intake. You don't mention if you have to comply with smog laws.
So running the AFR's, Around 11.1 c.r. ,Headers, FIRST intake, LT4 cam and a new chip.
Any Idea on RWHP Or a possible 1/4 mile time?
<sigh>
- You first define your intended usage....DD, weekend cruiser, drag racer, road race, etc.
- Identify what characteristics are acceptable...ie so much cam overlap the exhaust burns the eyes at idle, engine lopes like mad even at a 1000rpm idle....or....you want it to feel like a near stock engine, or somewhere in between
- Define your goals...desired power & rpm, trap speed if you intend to drag race.
- Define supporting components...ie rear gears you are using. Lastly, define your budget.
I have yet to meet anyone who randomly selected parts with no goals in mind that was happy with the outcome. In addition, if your goal is to run high 12s, that engine looks MUCH different than one needed to run low 10s.
Depending on the useability you're looking for, the 3.07s and 2400 stall aren't bad considering the amount of torque you'll be making. The low end grunt and low 1st gear of the 700r4 really help. I've got a mildly built 383 and for now am running the stock 2.73's, built 700r4 and a 2400 stall. I have zero problem with how hard it launches BUT I'm still built around the typical TPI powerband -5k rpm. If your build aims for more top end (*camshaft selection), you may want a higher stall. Most camshafts will have a recommendation for a complimenting stall speeds.
C4 of Year Winner (appearance mods) 2019
Actually, Will gave you a choice between two cams...the LPE219 is the proverbial "superram cam" but is also a great choice for a [super]large-tube FIRST (brand) intake. The other is an LT4 Hotcam.
Pick the LPE219 if you want a bit more power/torque. IMHO, the Hotcam is a better choice if you're more concerned with longevity.
Both will work great.
Don't be fooled by the lowish project for HP. The FIRST makes it's power by 5k rpms -- which means the torque is there for a 450ishHP motor. [Torque would be in the 450 range at the wheels.) You just won't be revving it high enough to make the HP numbers. But, it will still be fast enough on the track -- while being even more fun on the street.
BTW...There have been a couple of guys working on a FIRST build using AFR195's and a FIRST intake. They both believed it would be possible to go well past 350rwhp using that intake on an AFR/383. My guess is they would be right.
listen very carefully to this. it's very important that you do since your build is taylored around this very idea. just one example is with the ET. if you only want high 12s using the stock heads and a shortish duration cam with fast ramps will easily do it with 383ci. going for 10s......is completely different
