New Mod installed - Nice gains
Old May 11, 2002 | 11:59 PM
Vic'89's Avatar
Vic'89
Default New Mod installed - Nice gains
The AS&M runners were installed this week. Today they were track tested. The only change was the runners.
The weather conditions were 65 degs, 30.30 baro, 50% humidity.
My current TPI combo is:
Accel base + AS&M runners + ported plenum + stock 48mm TB.
The best run was a 12.81 at 107.09 with a 1.73 60' time. This is .15 better than my last run , which was run under better weather conditions.
I also picked up about 1.5 - 2 mph.
Attached are some timeslips. The Vette is now solidly in the 12.8's.
Fuel pressure was 40-41 psi , Coolant temps were 165- 170 degs.
I would also like to thank 65Z01 for lending me his brand new AS&M runners. He never installed them and basically handed me the box.
All comments and questions welcomed.
Vic
Old May 12, 2002 | 12:03 AM
scorp508's Avatar
scorp508
Excellent news! :D
Old May 12, 2002 | 12:16 AM
vader86's Avatar
vader86
Default Re: (scorp508)
:cheers: :cheers:
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: New Mod installed - Nice gains (Vic'89)
First off Vic... :cheers:...and isn't that your best short time too.
I'm glad that intake combo got the job done for you.
Assuming you weighed in at 3280lbs, that computes to 311hp, normalized for weather!! Very nice indeed.
BTW, what was your trap speed on that 04/06/02 time slip with the 12.95sec ET?
Old May 12, 2002 | 12:29 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
Old May 12, 2002 | 12:44 AM
Aggravated4life's Avatar
Aggravated4life
Thats great news...so the results is the stock runners were holding you back eh?
I got to say your mods and times are exactly what GM shouldve sold the car off the showroom floor with.Nice to see that someone has gotten the L98 into the 12s with basically bolt on mods.
:D
Old May 12, 2002 | 01:31 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Vic, comparing today's Time Slips with some from last year, I gained 3 tenths with my new exhaust and another 1.5 mph.
Old May 12, 2002 | 02:32 AM
robblk90's Avatar
robblk90
Default Re: New Mod installed - Nice gains (Mr Mojo)
Nice gain Vic. What exactly is the difference in the SLP runners and the AS&M runners? Are the runners you used the large tube or the semi siamesed?
Old May 12, 2002 | 11:05 AM
Rob90's Avatar
Rob90
Default Re: New Mod installed - Nice gains (robblk90)
Thanks for the info Vic. Just got the Accel base and AS&M runners myself. Hope to be in the 12s by the end of the summer
Old May 12, 2002 | 11:29 AM
NUckINg FuTS's Avatar
NUckINg FuTS
Congrats on the new times!
BTW, were you running 40psi w/ vacuum or w/o. Also are you running stock injectors?
Old May 12, 2002 | 11:47 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
That rocks!!!! That is the coolest thing about these old L98's, you can mod them to run 12's and still retain decent mileage and driveability. I am hoping to run high 12's with mine this season before I yank the motor.
Old May 12, 2002 | 03:03 PM
DragMan's Avatar
DragMan
QUESTION I HAVE IS 65Z01 GOING TO GET BACK HIS RUNNERS!! :D
[Modified by DragMan, 2:04 PM 5/12/2002]
Old May 12, 2002 | 03:07 PM
65Z01's Avatar
65Z01
Default Re: New Mod installed - Nice gains (DragMan)
After seeing Vic's gains, if I get the runners back I want the Accel base with em. :D
Old May 12, 2002 | 03:49 PM
scorp508's Avatar
scorp508
Man... when you even up the HP to the LT1, it really shows how torquey these things are. :)
Old May 12, 2002 | 04:13 PM
Vette9d1's Avatar
Vette9d1
So approximately how much of a horsepower gain is this? I knew that when you put the runners on it would make a difference!
Old May 12, 2002 | 04:17 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default nice gains indeed!!!!
I am gonna test mine out in a couple of weeks....I too would love to get my L-98 into the 13's and 12's if possible....but I dont' have a ton of cash....so just gonna have to wait till I can....and learn too how to install and do everything that Vic and 65Z01 did.
Jeff
hoping for a 13.7 or better at the track....
[Modified by XtremeVette, 3:21 PM 5/12/2002]
Vic'89's Avatar
Vic'89
Default Re: New Mod installed - Nice gains (65Z01)
Thanks everyone.
To answer some questions:
65Z01 -> Those were my best 60' times, so NO lose of bottom end torque. The best run from 4/6 was 12.96 at 105.xx, the other runs were 12.97-13.03.
My car only ran a 12.85 once before in 45 deg weather with a very high baro. The rest of the runs were 12.93 and above.
Yesterday I was in the low 12.8's all day. MPH was 106.xx to 107 all day
Bills86coupe -> The base without the runners didn't give me any gain.
Robblk90 -> They are the AS&M long tube runners, not the siamesed runners.
Nucking Futs -> I have stock 22lbs injectors, they have 74K miles on them. I also run 40-41.5 psi ont he fuel pressure with the vacuum hose disconnected.
Also, my shift points are not perfect yet. The 1-2 shift was at 4400rpms and the 2-3 shift was at 4900 rpms. I was messing with the governor during the week and I didn't set the shift points correctly.
Vic
To New Mod installed - Nice gains
Old May 12, 2002 | 05:13 PM
65Z01's Avatar
65Z01
Vic, taking that prior as a 105.5mph it computes to a 12hp gain, normalized for weather.
From your trap speeds it looks like you have another tenth of so in there. Maybe upping the shifts to 5k will do the job.
You're realy making these L98s look great and you still have heads (25hp), headers (20hp) and 1.5RRs (15hp) to go. Looks like you can be at 370hp without even doing a cam! You're definitely going into the low 12s in the future.
Old May 12, 2002 | 05:18 PM
scorp508's Avatar
scorp508
Jim I think a cam will be necessary to do low 12s. I don't think the stock cam can flow all of the air that would be brought in with heads etc....
Old May 12, 2002 | 05:26 PM
65Z01's Avatar
65Z01
Scorp, you may be right though 1.6s with the stock cam takes it pretty close to the ZZ-9, except for LSA. Even if he picks up another 50hp without the cam it would put him over 111mph and into the low 12s, assuming it still hooks.
I'm sending you the mods results data I'm basing my HP estimates from.
