[Fireup time?]: Almost done.
Old May 12, 2002 | 01:22 AM
scorp508's Avatar
scorp508
Default [Fireup time?]: Almost done.
Well, there is a big if the weather holds up tomorrow. The afternoon isn't looking good.
Either way, the car is almost completely together now. What might I overlook once I've got all the big things installed?
1. Fill Oil
2. Fill Coolant
3. Fill Overdrive
4. Install O2 Sensor
5. Set timing to 6* BTDC (for now, if it fires ;))
6. Torque crank pulley bolt now that the tranny is on.
7. Look at parts pile for spares
Old May 12, 2002 | 01:25 AM
jfb's Avatar
jfb
Default Re: [Fireup time?]: Almost done. (scorp508)
Stick distributor shaft into the oil pump and run the oil pump with a drill so oil fills all the oil passages and maintains all those bearings you replaced.
Old May 12, 2002 | 01:27 AM
scorp508's Avatar
scorp508
Default Re: [Fireup time?]: Almost done. (jfb)
:yesnod: I've got Morosso p/n 62200 here ready for the job. :)
Old May 12, 2002 | 01:29 AM
Vic'89's Avatar
Vic'89
That's a great idea for a new motor, but Scorp didn't replace any crank,rod, or cam bearings.
Vic
Old May 12, 2002 | 01:31 AM
RocketSled's Avatar
RocketSled
TTT!
Scorp, by now you should be INTIMATELY familiar with your car, just go over it with a fine tooth'd comb...check vacuum, check grounds, check hoses, if there's stuff not connected know WHY (like the throttlebody bypass on my car).
When you go to fire it up, get Cyl #1 at TDC on the compression stroke, set the rotor at 6 degrees BTDC with the computer advance disconnected and it'll at least run.
I dumped coolant on the header...smoked like an SOB! And was panicking for a sec until I realized it didn't smell like oil, or insulation, or wireing...
No sweat, you'll get it. Just keep the fire extingusher on hand and watch Voltage and Oil while starting up! (If Voltage is odd, it could be a short, if Oil is odd, well, watch it!)
[Modified by RocketSled, 10:32 PM 5/11/2002]
Old May 12, 2002 | 01:34 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Id prime it anyways to get oil everywhere before firing.Peace of mind.
Also be sure to prime the fuel rail a few times and check for leaks like 10 times.
Check the fuel line CS plug screw in the rear as well for possible leaks if you havent done this already.
Also be sure battery is charged.
Old May 12, 2002 | 01:35 AM
scorp508's Avatar
scorp508
Thanks guys, keep them coming. I did an initial lookover today while I was out there contemplating how to get the rear #8 header bolt. :)
Adjust TPS
Adjust Fuel Pressure w/vacuum line off.
The only electrical connectors left are the MAF, Distributor stuff, and Battery.
Old May 12, 2002 | 01:56 AM
18carfan's Avatar
18carfan
Default Re: (scorp508)
I haven't kept very good tabs on "everything" you've done but I think I have a pretty good grip on it. You are going to run a MAF still right? If memory serves that's the plan. It will make things much easier to start with. MAP cars don't react as well to the mods you're doing. I truly hope this project gets you to a point that will keep you happy for at least awhile. You've spent so much time on it (wish I could find that kinda time). I want your car to "kick azz"! I wish I could make it to BG this year so I could "talk you into" putting that baby on the strip. I had a blast there last year. If you need ANYTHING from me let me know. I'll take care of you. After all, you're pretty much the C4 celebrity around here. Wish I had the time to post like u! I learn more from all the folks 'round here then GM could ever dream about teaching me :). Looking forward to hearing good news soon! -Jeff
Old May 12, 2002 | 11:45 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Whoo Hoo! We're keeping our fingers crossed for ya there Scorp ole boy! Make sure Pops is out there with the camera when it gets fired up!!! We all want to see your reaction! :cheers:
Old May 12, 2002 | 11:53 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Sounds exciting!
I can't wait for the next post- [fireupdone!] She's running! :cheers: :cheers:
Old May 12, 2002 | 12:38 PM
lampedusa's Avatar
lampedusa
Default Re: [Fireup time?]: Almost done. (Mervz)
Got any pictures for us as of now? I don't think that we've seen a pic yet of it as of now, at least not with both hookers installed. Um, timing I guess, but you already have that one.
Old May 12, 2002 | 12:44 PM
Red94Vette's Avatar
Red94Vette
Default Re: [Fireup time?]: Almost done. (lampedusa)
Turn the key to ignition and watch for fuel leaks before firing it off.
Old May 12, 2002 | 01:45 PM
scorp508's Avatar
scorp508
I didn't take shots of that last night, sorry. :(
I got the driveline support beam and driveshaft in today. It started raining so I am off to the store to buy what is hopefully the last batch of stuff. Spark plugs, oil filters, oil, etc.....
Here is how she sits right now in the rain. She came down off the jackstands today. I was actually excited when I had to engage the parking brake for the first time in almost 2 month. :rolleyes: She's gotta go up one more time for me to put the catback on.
[Modified by scorp508, 12:50 PM 5/12/2002]
Old May 12, 2002 | 04:31 PM
LPDesRoche's Avatar
LPDesRoche
You won't melt in the rain, get an umbrella and get to starting!!!!!
Sad thing is I have done that before... :D
Old May 12, 2002 | 04:33 PM
scorp508's Avatar
scorp508
Sure I will. :D
I just got back form the stores. No sparkplugs at pepboys, grr... and no screws for the superram lid at home depot. :(
Old May 12, 2002 | 04:45 PM
pablocruise's Avatar
pablocruise
with the loop in I hope? It's really easy when the beam is out.
Old May 12, 2002 | 04:47 PM
scorp508's Avatar
scorp508
Not yet. I plan on pulling the driveshaft again to do the u-joints soon for peace of mind. Then it'll go in. :)
To [Fireup time?]: Almost done.
Old May 12, 2002 | 04:53 PM
pablocruise
I thought ya just did them a short while back? It was your u-joint posts that inspired me to do mine(thanks).
Pray to the god of corvette half shafts and yokes your new torque monster doesn't twist them, since the new u-joints won't be the weak-link in the chain IMHO. I'll look forward to see of your results.
:cheers:
Old May 12, 2002 | 05:02 PM
scorp508's Avatar
scorp508
I only did the halfshafts, never did the driveshaft. I've already got 3 spare halfshafts & u-joints lined up for "when" it happens. :)
Old May 12, 2002 | 05:14 PM
lampedusa's Avatar
lampedusa
Hey Scorp, what heads did you use? Or didn't you get any? And was the installation of the Superam easy or rather difficult? She looks great even on jacks, but one more thing: What to name this new beauty. Make a separate topic for her name!!!
