Engine Shake
Old Jan 20, 2012 | 07:24 PM
Bredd1's Avatar
Bredd1
Default Engine Shake
At idle or standing still, my engine & whole car kinda shakes or lobes as if it had a big cam. I've checked & adjusted the timing, a full tune-up has been done including replacing the disributor, ignition coil, plugs, & wires. The engine seems to run fine except for the shaking. Any ideas of what I can check or change.
Old Jan 20, 2012 | 08:30 PM
pcolt94's Avatar
pcolt94
Do a compression check.
How does the coolant look?
Check valve clearances.
Had a strange and similar problem 25 years ago were the lobes on the cam had worn down. Probably not your problem though.
Old Jan 20, 2012 | 08:46 PM
Bredd1's Avatar
Bredd1
The coolant looks ok, it was recently put in after the head gaskets were replaced. How do you check the valve clearances?
Old Jan 20, 2012 | 09:43 PM
1986coupe's Avatar
1986coupe
Are you sure all cylinders are firing? How did the old plugs look when you removed them?
How do the engine mounts look?
Old Jan 20, 2012 | 09:53 PM
Bredd1's Avatar
Bredd1
I checked the new plugs after running them a while and they all looked as though they had been firing, none were wet. I am going to have to check the engine mounts tomorrow. Strange thing though, even if I remove the plug wire from any of the cylinders, I really can't tell if it skips.
Old Jan 21, 2012 | 12:09 AM
overdrawn's Avatar
overdrawn
harmonic balancer?
Old Jan 21, 2012 | 08:18 AM
Bredd1's Avatar
Bredd1
Originally Posted by overdrawn
harmonic balancer?
How can I tell if the harmonic balancer is bad?
I did question if it could have gone bad due to me turning the engine with the mounting bolt when I was setting the valves.
To Engine Shake
