she died...
Old Jan 22, 2012 | 06:13 AM
Fredbird's Avatar
Fredbird
Default she died...
Swapped out injectors, EGR, and fuel regulator today. Everything seemed to go great. Started it up and idled very smooth. No more pitting etc.
I let it idle for about 15 minutes and it sounded great so I decided to take a quick drive.
Got no more than a few miles away, I shut it off in the parking lot and started it again a couple times. Now, nothing works... Lights, radio, inet cluster etc. And of course, she won't start.
If i try to start it... I hear a really faint chime, and thats it.
HELP!
Old Jan 22, 2012 | 06:21 AM
lvbg1435's Avatar
lvbg1435
HELP!
i know this going to sound lame but have you checked your battery cables is the positive lose?
Old Jan 22, 2012 | 06:46 AM
Fredbird's Avatar
Fredbird
I checked the before I left the house.
However, I just now disconnected the battery cable, reconnected it, and everything started working again. Don't know what that means... Reboot of computer?
Old Jan 22, 2012 | 07:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
However, I just now disconnected the battery cable, reconnected it, and everything started working again. Don't know what that means...?
It means you had a really poor connection at battery terminal.
Old Jan 22, 2012 | 08:24 AM
PAINTER MAN's Avatar
PAINTER MAN
Sounds right to me.
Old Jan 22, 2012 | 08:54 AM
Fredbird's Avatar
Fredbird
Hope so...
Old Jan 22, 2012 | 06:12 PM
Fredbird's Avatar
Fredbird
It happened again today.... Same scenerio. Drive home, shut it off, and then tried to start it again. All the lights came on for a second and then EVERYTHING send dead. Interior lights, exterior lights, windows... Everything. Only thing that happens is if I try to start the car and then turn the key back to the off pos. It chimes very faintly.
I disconnect the battery, and connect it again, and everything works.
I will check for a bad power cable, and try giggling them when it does this again.
Old Jan 22, 2012 | 06:20 PM
aminnich's Avatar
aminnich
Telling them dirty jokes???
Old Jan 22, 2012 | 08:59 PM
Fredbird's Avatar
Fredbird
Hahaha! Didn't think about that other meaning when I typed that... Let me clarify... Jiggle the WIRES!
Old Jan 23, 2012 | 07:06 AM
lvbg1435's Avatar
lvbg1435
a white horse fell in the mud ..
Old Jan 23, 2012 | 09:18 AM
Muffin's Avatar
Muffin
While checking cables do not forget the starter and engine grounds.
Old Jan 23, 2012 | 10:41 AM
Fredbird's Avatar
Fredbird
Ended up being the Positive Battery Cable... (I THINK)
Usually I only disconnect the negitive cable, but recently I bought a battery tender and I now remember disconnecting the Postive at that time... I guess I didn't tighten it down very good...
To Quote Rick Perry... Oops...
Old Jan 24, 2012 | 08:44 PM
gunnerjuju's Avatar
gunnerjuju
She's alive. :-)
To she died...
