18 degree heads
Old Jan 24, 2012 | 09:44 AM
1991Z07's Avatar
1991Z07
Originally Posted by bjankuski
I am not saying a engine with heads like yours cannot make 750 HP, what I am pointing out is better flowing heads will make power more easily.
A rule of thumb is (intake flow X .256 X 8 = HP potential of a high performance street car), (intake flow x .280 x 8 = HP potential of a competition built engine designed for racing with limited on no street use), (intake flow x .311 x 8 = HP potential of an all out drag race engine, no compromises)
HP street (309 x .256 x 8) = 633 HP
Competition (309 x .280 x 8) = 692 HP
All out, no compromises (309 x .311 x 8) = 769 HP
These are rules of thumb and should only be used as that.
Good numbers to know...
Old Jan 24, 2012 | 10:08 AM
LD85's Avatar
LD85
Thanks Brian, your last engine build is on my list of truly impressive,
Old Jan 24, 2012 | 12:35 PM
1989TransAm's Avatar
1989TransAm
"I am not sure what your goals are but your combination could benifit from a cam with a tighter lobe seperation and more duration. It will idle rougher but it will hit harder and make more power if the cam was changed."
You are correct it sure will. However I have rules I have to abide by and they are CARB for smog. Also looking over the dyno results at LS1 Tech I see many motors with just about the same camshaft and similar components making more power. I believe with the 18/15 degree heads you do not need the larger camshaft to make the same horsepower because the heads are more efficient.
I also agree that the LSX style intake runners are very good. I am thinking about emulating them or going to a somewhat straight runner and drop the length to 15-16" in length and utilize the 3rd harmonic wave. I will see what my dyno results will be with the intake manifold I have that is now under construction and go from there.
Old Jan 24, 2012 | 01:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Old Jan 26, 2012 | 07:46 AM
yedister's Avatar
yedister
Originally Posted by 1991Z07
Not too sure why you would WANT to go that route.
Your engine @ 7K RPM's NEEDS 1,758 CFM. That would be about 280 CFM per cylinder.
A set of Brodix 23 deg. T1 M2's like I have flow 309 CFM's.
To convert to 18 deg. heads?
Custom Intake
Custom Headers
Both will cost you a BUNCH of money.
23 deg. intakes & headers?
LOTS of choices.
EASY decision...
a true18 degree head will outflow a normal 23 degree head, if you get a set of ALLPRO RR245 then you are in the same ball park. If you spend the money on the ALLPRO, you might as well get a 18/15 degree heads because the 18/15 degree will have a higher power potential.
Converting to a 18 degree set will only require custom piston, shaft rocker, offset lifter assembly and headers just like the ALLPRO. I know the AFR 245 looks good and AFR does deliver the flow they advertise but, 350 at .750 lift is a bit high for my taste on a street engine. There are off the shelf intakes, Edlebrock has 2 piece intakes that makes it easier for porting. There are plenty of used 18 degree parts to be had. I have a 15 degree head 434, I had my Miniram overhauled to work with the heads, since he wants to go with different intake, there are plenty to chose from.
Old Jan 26, 2012 | 08:01 AM
yedister's Avatar
yedister
With a better flowing/ port volume/MCA on the heads and intake combination, cam overlap cam be smaller to make the power he wants and where it needs to be. The LSX platform can not be compared to the 23 degree platform or 18 degree. If memory serves me, when the LSX first showed up, it had a 15 degree heads, now they are on a 12 degree head, much better port volume, runner shape in the heads and intake.
Old Jan 27, 2012 | 06:59 PM
vette 15x's Avatar
vette 15x
Default pondering 18 degree
Hi i'm john.I'm doing the 15 degree thing.Your not alone.My friend just built 420 15 deree thing.Hows 805 ponys sound.
Old Jan 27, 2012 | 07:07 PM
vette 15x's Avatar
vette 15x
Default 18 degree heads
Hi i'm john.I'm doing 400 sb 15 degree,so your not alone.My friend just dyno ed a 420 sb 15 degree at 805 ponys.If you do hang on for dear life.
Old Jan 27, 2012 | 08:12 PM
ddahlgren's Avatar
ddahlgren
"The AFR 235's flow in the 340cfm range, and the AFR 245's flow in the 350cfm range, both 18 degree territory."
I know what everyone is saying but I think there is more to this from my experiences. Comparing my motor to the LSX series I am down 30+ horsepower. Here are my stats.
1) 369cubes
2) 11.12:1 compression ratio
3) 280/280-233/233 camshaft on 113 LSA, .594" lift at valve.
4) AFR 210 heads modified by DR J., Flow 305cfm at .600" lift on his bench. Speed at the pushrod pinch is 315fps. 2.08/1.60 valves.
5.) Intake flows 336 cfm with maximum with max airspeed of 300fps at peak horsepower rpm of 6500rpm.
There is more to it the air speed numbers you quoted are mean air speed and the ones you want are peak air speed that is governed by rod ratio and cam timing if a low lift mild cam.
Old Jan 27, 2012 | 08:32 PM
vette 15x's Avatar
vette 15x
Default 18 &15 degree heads
Originally Posted by tpi 421 vette
The AFR 235's flow in the 340cfm range, and the AFR 245's flow in the 350cfm range, both 18 degree territory. And they use off the shelf 23 degree stuff, although the 245's require a shaft system.
18 &15 degree heads are plain more efficent in every way .Flow is not the only variable making h.p.And if your pulling a heavy sled around like corvette you should be aware of this.
Old Jan 28, 2012 | 06:24 AM
yedister's Avatar
yedister
More details about the combination please.
Old Feb 4, 2012 | 12:14 PM
vette 15x's Avatar
vette 15x
Default MYmotor
I'VE POSTED,my info of what i've had done so far in my thread "exhausted"
Old Feb 5, 2012 | 03:05 PM
  #33
vette 15x's Avatar
vette 15x
I'm happy for you,and hope you tell me more.7000 rpm ,fun.THE SB2 head is not your standard 15 degree head.
Old May 2, 2012 | 02:36 AM
  #34
ZD1's Avatar
ZD1
yeah but what most people dont realize is that most 18 degrees heas have way too big an intake port size for normal duty. If the port is too big, the flow will stall and you'll generate far to little dynamic pressure to effectively fill the cylinder...much less make effective vacuum.
just me but
a 355ci motor wants 165-195cc intake port size
a 383ci motor needs no more than 215cc
a 427-434 can take up to 250cc...i use a 227cc ported to 232ish
efficient heads mean that high mass flow for a small cross section...this is what AFR sells.
But when you need a sledge hammer....a 250-350cc port is needed to get the big flow numbers.
Old May 2, 2012 | 11:52 AM
  #35
Steve85's Avatar
Steve85
Cruise-In V Veteran
just me but
I don't think you can compare 23 - 18 head cc size directly. If I'm not mistaken, the 18 heads have a longer runner with the altered valve angle (the head is definitely taller) and that makes them cc larger for the same cross section.
My 18 heads took a 1206 gasket and were probably 250-260cc. The other thing that effects the comparison is the relocated pushrod. The pinch reduces the measured volume of the 23 runner and not in a good way.
This effect is also seen in the 15 degree LS series. The LS6 at 346 cubes got a 210cc runner.
Need to consider varied runner design when comparing cc as a gauge of efficiency
Old May 2, 2012 | 11:21 PM
  #36
ZD1's Avatar
ZD1
runner design does have a lot to say (straight flow) about the potential pumping efficiency of the head. raised port heads (up to 1.5") are probably the most efficiency, followed by the cathedral ports of the Ls1/2. However, big port race heads will always want larger cubes or higher RPM range.
When I choose my final design (is it ever done?), i went with a best flowing intake and then port matched to the MRIII (1209?), Displacement and cam just set the TQ where ever thing works. Sadly the 18x head lost out because I already had the intake I was invested in.
Having said that, my offset rockers should have yielded more flow than the heads gave up.
Old May 3, 2012 | 06:50 AM
  #37
ddahlgren's Avatar
ddahlgren
just me but
Who ever came up with runner cc's as a way to describe runner cross section was a moron at best. What you care about is minimum cross section that is measured in sq. in. cc is a measure of volume not area. Two different heads can have two different minimum cross sections with the same volume because of metal removed in different places it is as silly as describing the size of a room in cubic feet without knowing the ceiling height. TGhe person that dreamed this all up was just a lousy engineer period. For those that think an 18 degree head does not work with a 355 needs to live in a larger pond 750 to 800 hp is a walk in the park with them again it is about cross section not cc's.... Chamber shape and air speed are different and the 18 degree is better. The only drawback is the lack of non professionally built intake manifolds so expensive with no off the shelf solutions.
OK rant over time to go back to work making HP.. Dave
